  • Replies 14.2k
first day at work with the magistrates court was a sucess :D
good ppl and interesting work... already seen 2 ppl i know rock up to sort out their fees/fines.
had a celebration dinner on sat night with teh mrs. bought 2 300gm cuts of wagyu grade scotch fillet... at $90/Kg it is worth every cent! nothing better than a rare primo quality steak to get me going :cool:
I'm filling out my new contract and came across these thing that i dont know what they are or dont know how to find out where to find them.
SWIFT code
(Compulsory for ALL countries)
IBAN Code
(Compulsory for EU countries)
ABA Code ( for US)
or
BIC (Bank Identification Code)
It's for my pay to go in so I'm just wondering if i need them or not.
cheers
i think i may have just taken somebody's speeding fine.
South road, next to Mitsubishi's, there is a speed camera in the bedding place across the road, in the car park. I see the silver ford wagon, and assume it is a speed camera, so i go from 60, to 55kph, just to be safe. Meanwhile, i notice a car coming up my ass at a decent rate of speed, in the right hand lane.
so i pass through the camera, and it doesnt go off, but this car has flown past me, and the camera has flashed, as he is on my front quarter. Leaving only my numberplate in view.
The camera only flashed once, which i was suprised about. But being quick to think, i grabbed his rego, the make, model, colour, and time of this car, and noted it down on my phone.
Basically, i am waiting for the letter to come, assuming it's me that they think was speeding.
What can/should i do?
I'm on my P Plates, have been driving since i was 17, and am now 20, and have survived on one point for 2.5 years, and i really don't want to lose my licence for somebody elses disregard for speeding.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
