What about inertial dampeners or even anti gravity devices? I have both these features standard, they seem to treat me fine
oh, as long as your make sure you charge the flux capacitor to max, and enable the quad booster when using the anti-gravity device, you should be fine....
  • Replies 14.2k
Tshirt hell editor strikes again, so very wrong, but so very hilarious.
Our prophet Mohammed not to be mocked in such a way as this!!! > Our prophet Mohammed is for all people and not just Muslim so even Christain and Jewish should be respecting of Mohammed!!! > Take this shirt off from your computer or like many others you will know this is no joke!!!!!
Are you sure this is no joke? I would think anything that makes me laugh this hard has to be a joke. You have inadvertently cut to the core of the existential nature of comedy. Sort of like humor's version of "I think therefore I am" or "If a tree falls in the woods, why does your mom take so many cocks in the ass?" I laughed at your email, therefore it's a joke. Like people in nursing homes or that WWII footage of a bulldozer filling a ditch with bodies.
Forget all that. Thanks for your email, Faiyaz (Whoa, a brown version of Beetlejuice just showed up in my living room). It was nice to hear from the douche above, but I couldn't fully understand how a mentally Muslimed person would take this until getting it right from the source. And I gotta tell ya, this was some delicious idiocy. No cutting or distillation here; just 100% dumbf**k straight from the tap... mmmm. And now, a word from Allah:
"Hey, dicks who worship me: give it a rest. It took Christians 20 centuries too long, but at least they eventually evolved from 'violent assholes' to 'hypocritical douchebags.' So what's the holdup? Do you think rubble and brown water are blessings? I've got news for you: I made your lives as shitty as possible so you'd bail on this nonsense and move on to greener pastures already. Which would be any other pastures on the planet.
Yeah, so I gave you oil. It made ten of you rich and the rest of you get your plywood shacks blown up every other week. What do I have to do, put a plague on your beard or take away your... shit, you don't even have anything I can take away! Just f**k off!"
Can you believe I got Allah to open up like that? It's almost as if I pulled that out of my ass and tried to pass it off as the words of your deity. But there's no way I did that, because that's impossible. And no one has done it. Ever.
haha, i was starting to get over them
now that confirmed it. cant even order a set of CC plates online FFS
and i have to start being a tight flamin mongrel - i own a GTR now :(
why not matty? I ordered mine online 3 weeks ago and all worked out. tWas 150ish as a one off payment
i cant even renew my rego online, its bs
plates cant be ordered because:
This plate has not been pre-manufactured with the expected colour and size.
For assistance please call 131084
then again, the next plate in the series apparently is BB469X
cant renew my rego online (or at the post office) cos of the plate agreement that has to be renewed
Cheers mang :(
Perfect caption, I'll have some R33 GT-R wheels on it this weekend too otherwise I probably won't do much else to it looks wise other then paint the wheels white. I want a supermade instant gentelman front bar (i think thats what it is) but I'll probably just smash it on a tyre wall anyway so seems a bit pointless and a waste of good $ to me :( .
Don't get one, if you don't smash it on the tyres you will smash it on the ripple strips. They're a lot bigger than they look.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
