yeh man the plenum is all good.. it JUST fits under the bonnet!!! way too close.. cant run strut brace anymore.
um im getting paul from red r racing in sydney to do the build.. should have it beack in adelaide next weekend of during the week after..
  • Replies 14.2k
Well my rebuild budget just blew out AGAIN.
Paid for the head today, was expecting it to come to around $600. The bill come too $1070.
This is on-top of the $240 for parts i supplied and $650 for the cams.
Original budget was around $2780
I'm at $4350 and i haven't even assembled it yet. you could add another 3-400 for incidentals on top of that as well.
Wayne
Payment details
Name: Skylines Australia - SA Chapter
BSB: 105 192
ACC: 028 822 340
use your member name and and Membership as a description EG: Wayne Membership
Do I transfer them funds now or wait untill my application has been received?
just going to throw it out there....
how many people would be keen for a private track day? (drifting of course)
not going to organise anything till i get my roster sorted so i know when im back on shore but would like to know the numbers from here as ill have a few mates keen.
yerp, keen
Mega keen!
Skyline is still broken from the SAU grip day so drift is all i have these days. I hate not being able to drive it :D
yeah i thought there would be at least 4 from here which is cool.
ill keep the list with me and get it moving as soon as i can get my rosters sorted out.
DOES ANYONE KNOW OF ANY R32 GTST ROLLING SHELLS THAT CAN BE REGO'D THAT I CAN BUY?
We have talked about an SAU:SA drift day, but there are only 6 or so drifters on SAU, so around 20 people short for a private day. But apart from that, nearly all of them won't even pony up the whole $30 per annum to support the club, so it is pretty much off the table of events ....
max of like 10 for a drift day, actual
If you offered something for drifters then we'd most likely join up.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
