For all you IT people
Is it possible to get a SCSI to COM port converter? Or even SCSI to USB?
f**king new server that came in doesn't have a SCSI port and I don't have time to order a SCSI card...
Need it for a bullshit tape drive.
Nope. Not a chance. (I wish - it'd be much cheaper)
Are you after a std 50 pin card or something that needs 68 pin lvd?
-D
  • Replies 14.2k
I can imagine you'd have a number of issues with a USB SCSI converter - both in terms of performance (depending, USB2 will max out at between 30-60MB/s) , and in all likelihood the tape drive will require LVD SCSI (most tape drives do) - which I don't think you're going to find a USB SCSI converter supporting (or at least at a reasonable cost)
What sort of server is it? Reasonably recent? PCI/PCI-X/PCIe?
And yeah - Plain ol' SCSI is just about dead really - SAS (Serial Attached SCSI) is pretty much what everything server-grade comes with these days.
Brand new Dell - PCIe compatible from the top of my head.
I might have to shop around for a card...
Ring ServiceSA brother. They'll have all the information.
yep, motor reg are the guys to call. i have access to TRUMPS at work, but its the "lite" version and unfortunately is read only, and does not show demerit... so dont even ask me to sort out ur demerit points :)
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
