Try outlaw speed shop in the city or main north road Nigel!
p.s. Andrew: http://www.skylinesaustralia.com/forums/19...ls-t312968.html
I can not put in words how f**king sick these would look on your 35 man!!!
  • Replies 14.2k
does anyone know where the heck i can get some of these style clamps from today?
they are called "constant tension" , "preformed" or spring band clamps"
from my understanding, they are a factory-only style clamp, and are rarely sold aftermarket.
Tridon make them, as do a few other smaller brands.
need some 23 and 25mm ones TODAY, and have already tried the following:
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
any other suggestions?
http://www.smartbuild.com.au/business-list...es/wingfield/sa
Give them guys a buzz see if they got it.
Ive only ever heard that from you. Been running gates belt for over a year and never noticed any difference in noise.
-D
the only time you should really hear a timing belt is when its on too tight and it'll make a buzzing or humming sound.
Nah mate don't do anything for me .... plus I am a bit in love with my LMGT4 copies :)
Whats it going in? sell me the head cheap so I can build a RB30DET for my drift car :)
I am building up a RB27 - RB25 Block with 26 Crank, Rods with over-sized Pistons, along with having Pon/Pro Cams and porting on the head. So the head isn't for sale, but you are welcome to buy the cam covers or swap for RB26 cam covers plus cash your way.
i suspect thatll be a no go Wayne, Abe searched for ages to find that 25 head!
Indeed I did, found via Facebook, thanks to Dion for pointing it out for me, and I picked it up for a decent price too, $350.
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
I wouldn't put those on my car, fact is when i replace the hoses they go in the junk box
the custom one on my 3lt is a dayco / gates generic one and its hummed from day dot. Its installed correctly as well (using two tensioners to get the correct spec) so it may be a luck of the draw.
FWIW i wouldnt use a trust / gates painted belt either as they have no stretch on the coating and go tight as the motor warms up.
Std nissan parts at all times, unless there's a reason (ie like dark mentioned with the water pump elongated hole bs)
so abe do i get to take the valve covers to use for carbon fibre molds? you can have them back unscathed , timing covers too???? intake plenum ???
let me know if you want help porting and polishing the head, gasket matching the ports ? done a few in my day..lol
crack test with tracer dye... the head before doing anything to it
and gates belts rock, they used to make them down the road from me in USA, gates batteries(optima as well)
Shit yeah!
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
