ugh. what a morning. bottomed out hard. smashed my intercooler mounts. bent my castor brackets. probably f**ked my exhaust. rails look alright.
probably take it down to a chassis joint on tuesday to make sure everything else is fine, then start replacing the bent bits.
WTF?!?!? What happened Dave!?!?
  • Replies 14.2k
hmmmm so dale has kindly done some research on this turbs i have
sittin here...
Seems its a TD06-17c.
which will apparently be capable of 17ish psi by 3700ish rpm,.....
kinda got my juices flowing!!
not sure what to do now, VG30 or TD06?
100 bucks difference in the 2, i know the VG is in good nic as it will be comin from jeff @ speedlab....
never seen this turbs on a 20 before so makes my decision a little harder
TDO6-17C = yes. i had one that i was going to use but i decided to go silly
HKS 25/30 is equal if not the better jap turbo :) (contradicting myself cos clearly its a garrett after all)
VG = laggy as f**k
RB25 turbo = laggy, but not as laggy as a VG
if you're goin to buy new, i can only give a bit of advice that dale gave me, and either go with a GT2871 or my choice the 3071 :)
If the TD06 can pull up 17psi by 3700rpm on a 20 I would go that personally. I was trying to minimise lag on an already laggy motor so I chose the HKS 2530 - it's the undisputed turbo of turbos for an RB20 haha.
Good luck with it, interested to see how it goes.
Edit: Never driven one, but I've heard the VG30 turbo is rather laggy on the 20.
damnit, should have read my second quoted post BEFORE writing all that haha
ugh. dont ask dude.
So want to ask hey :)
Anyway I'm slowly becoming more and more sober so yeah I'll just say that driving home from mannum and texting your girlfriend whislt tyring to decide which of the 2 centre lines your going to try and follow is not the greatest of ideas but I made it home and have just smashed through a maccas bacon and egg roll and am now going to bed :)
The HKS 2530 is almost the same turbo as the Garrett GT2860RS (Disco-Potato) with the only difference being a slightly bigger inducer on the compressor (0.5mm) on the HKS version. And considdering the you can pick up the dancing spud for around the $1300 mark it (i'd hate to know what the retail is on the HSK item?) would be the way i'd be going if tossing up between the two. I don't know if you can find a T3 flange for the 2860 though.
The TD is a lot bigger turbo than the 2530 though, it's even bigger than a 2871R and ever so smaller than the 3071R.
Does anyone have the wheel specs for the standard R33 turbo?
And just to make the decission making process harder, here's another turbo that is spec'd inbetween the GT2860RS and the GT2871R, A HKS GT2535; Bit more Exxy though;
http://www.nissansilvia.com/forums/index.p...howtopic=415365
Edited by D_Stirls
I was going to buy a HKS 2530 brand new, while the retail isnt cheap they perform better than a "Garret rebuilt" 2530. The fin design is different so the genuine HKS ones spool faster. One of my friends got me an AWESOME price on a brand newy - about $400 more than a brand new 2871 - note the kit from a reputable dealer is $2999. But then I found a genuine 2530 with only 2000kms on it since brand new, fitted/tuned by trusted workshops/tuners here in Adelaide for less than a brand new 2871.
Garrett make the HKS CHRA's, the difference is that HKS clip some of the Garrett wheels and HKS make their own housings.
Ask discopotato03 one here for the details as he knows his HKS/Garrett stuff backwards.
Edited by D_Stirls
your not going to like what i'm going to say but; you can actually do it yourself. They are a very basic turbo in terms of their bearing/core design.
The main thing is to make sure that you index all the compressor side parts that you take off so you can make sure that you put them back together exactally the same so you don;t then have to re-balance the assembly.
hmmm, ill give it a shot. if the kit gets here by friday, ill have 2 weekends to do it before
the rb20 goes in...
actually looking forowrd to gettin my hands dirty and doin some shit myself on this build, makes it more pleasing.
starting on ripping the 30 out today, perfect weather for it! :)
Ok Cheers, will give him a yell.
I dont know 100%, but I think:
RB20 Turbo = .46
RB25 Turbo = .58
RB25NEO/VG30 Turbo = .63
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
