  • Replies 14.2k
some guy wants to swap me for this plus cash my way
it now rolls on work vxmx mmmmmmmmmmm
http://www.nissansilvia.com/forums/index.p...p;#entry5824703
opinions?
also a 180 that i dont have any detaila on yet
That S13 is good man,
You will have to spend a fair bit of coin on getting it to slide really well however given its a straight swap for the R31 I'd say thats pretty decent deal for yourself man.
i feel like im ripping myself off... i dunno
you are, I'd stick with the 31. You've come this far with it why not stick with it. It's enough to learn in, get as good as you can in the car then maybe look at upgrading
found out a cpl days ago my rear turbo was wak.
spittin oil into the pressured intake side
that explains the detonation
praise yoda that i have replacement turbos to go
the horse will be with u
-D
Isn't that normal because the oil breather plumbs into the intake pipe before the rear turbo? I may be wrong.
cost and worth are 2 different things
i wont tell you what the R33 has cost me and what im told it's worth but its sad panda indeed
what ever its cost you then times that by 2 or 3 and thats how much i have prob spent
im too scared to add up all my receipts
im over it!
random question
Does anyone work at a place, or know where I could get a 6 way TV splitter tomorrow? like a Hills, or a Clipsal one?
Just spent $73 on a HD set top box to find out my TV in my gaming room isn't connected to the 4 way splitter in the roof... grrrr
/rant.
Guys, I see in some signatures a Dyno Day coming up for SAU - can non members get any more details?
AWD dyno?
Location?
Non-members welcome?
Cheers
Lee
Hey Lee, at this stage it is open to members only, but if there are some spots left in just over a week or so time, then it will open up to non members. Ill just say that its AWD and non members will have to pay $45
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
