Isn't that normal because the oil breather plumbs into the intake pipe before the rear turbo? I may be wrong.
if thats the case, its not a related issue. should really take pics of my piping before I clean it out... theres too much oil in there to be normal
-D
  • Replies 14.2k
random question
Does anyone work at a place, or know where I could get a 6 way TV splitter tomorrow? like a Hills, or a Clipsal one?
Just spent $73 on a HD set top box to find out my TV in my gaming room isn't connected to the 4 way splitter in the roof... grrrr
/rant.
jaycar
Interesting, you can lease an R35 GTR MY10 Premium
FULLY maintained: $ 3,773.34 per month inc. GST
ill keep that in mind if i ever find an extra $4k a month burning a hole in my pocket.
Dion i need cash for the clutch this weekend, i thought the manufacturer was going to send them through and i pay later but its cash first i can come out to you if its hard for you to get about txt or ring me when you see this 0421932750
Well that was good timing, seeing as I just got up lol
I want these for my rex. I got some saving to do but what do you think?...
http://cgi.ebay.com.au/18-ROTA-GFORCE-WHEE...=item19b7fa3c7c
HELL NO! Get geniune works for that price and your not giving money to a company that blatantly copies other company designs.
Sent you a text before, Im guessing youre at work... Or my last text didnt work lol
Here is there whole cataloge
http://www.rotawheels.com/wheelcatalog.asp
All of them are direct rip offs of Work Emotion series, Work Meisters, Rays/Volk and Advan racing.
And unfortunately they don't "slightly" change them like Drift-Teks did compared to the Bee-R orignials.
As soon as I seen them I was like :( 11R's wtf? lol
:D
You could get genuine works from streeter sent in whatever offset you want for probably $1,600.
:D
The Rota G-Force is a copy of the Advan RS wheel.
11R's are very similar to Advan RS-D which is basically an RS with Dish.
Every company has similar looking wheels, and it depends what you want to run on your car - i.e. $3k worth of rims (genuine advans), $1.6k worth (work) , or $1k(rota). Its a personal choice.
Personally, I bought second hand Gram Lights 57Fs (forged) as they suited the car and application better, BUT i did consider the Rota G-Force at one stage as there is no way I can justify $3k on rims
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
