^^^ bloody AWESOME bike there! Sooo cheap too.
Glad to hear you are bouncing back Brendan - we are all worried for you mate .... chin up - it will all work out!
You will love getting into cycling - I wish I had the time to do it.
  • Replies 14.2k
thanks mate, looking forward with renewed optimism
ambition is to get these legs strong to support the lack of stability / pain
arranging interviews this week thru a govt. initiative to get ppl off disability pension & back into the workforce
will only be looking for a 38hr per fortnight job, to get back into living.
got to buy myself another house, selling current home - 10 christine street, morphett vale, $395k LOL, exwife gets half and otherhalf to my two young children
after starting paying off my 1st home from age 17 Ive got to start back down the bottom.
tbqh: would like to run for state parliament as an independent. going to look into it over the next 3yrs
ordered all this:
Bicycle Bike Tool Kit Puncture Repair Saddle Bag AU $19.99
ROVE PADDED CYCLING KNICKS/SHORTS SIZE XXL AU $19.99
SHIMANO CLIPLESS MOUNTAIN BIKE PEDALS PD-M520+CLEATS AU $48.00
WELLGO/XPEDO LONG SLEEVE CYCLING/BICYCLE JERSEY XXXL AU $19.00
HASA BICYCLE/CYCLING JERSEY SIZE XXXL AU $19.99
HASA CARBON ROAD BIKE/RACER SHIMANO TIAGRA 600mm AU $849.00
BICYCLE/CYCLING SHORTS/PANTS EXTRA THICK XXL AU $35.00
$1125.00 delivered from ebay cyclingdepot
SHIMANO M086 MEN'S MOUNTAIN CYCLING SHOES MTB EU 48 AU $130.00 delivered, ebay usa
need helmet, handpump, lights for around another $100 all up from a local bike store
not too bad for under $1400.00 all up
going to enjoy it, should be a top quality setup to get into the cycling
cant ride motorbikes (ex passion, which replaced footy - sth adelaide panthers, fitzy took my spot on the list when i 'retired' after knee surgeries)
so Im looking forward to an awesome new hobby, get me mentally and physically stronger
good to hear Brendan those two numbers aren't spread around enough some times
i quite often hear them on LifeFM
riding will do the heart good ;)
iv'e been clean of all drugs about 9 years and also wouldn't look back
Do the "anti-squeal" plates on the back of brake pads perform any real task or can I rip them out? All they do is squeal, I've applied some anti-squeal gummy paste to them but that only lasted a couple of months.
Yes, you NEED the anti-squeal plates. And you need to slather them with anti-squeal goo - not just a little bit. Buy the good stuff too - the really sticky orange stuff is usually the best.
CRC Disc Brake Quiet is what I have - bright redish, used a whole bottle per axle and coated every surface between the rear of the pad and pistons. Guess I'll just re-apply and hope it keeps working this time.
try chamfering the edges of the pad slightly, new pads with old rotors, or old pads with new rotors have a tendency to squeal. make sure all of your slides are lubed too, just in case they are sticking, causing the pads to stay in contact.
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
