  • Replies 14.2k
get the sherrifs to break the guys arm? theyre usually pretty obliging :D
-D
id rather sort em out at the counter than having to get the sherrifs to put them in a kung fu grip and boot em out the door.... just makes them angrier for nextr time.
must say its pretty entertaining seeing a massive biker getting taken down, and start screaming like an 8 year old girl with a grazed knee at the hands of a small asian sherrif though
think i found my new hangout when im bored !
How's this.
Brother was driving his n14 pulsar last night. Went through a deep puddle of water and got into his airbox into the engine and blew the motor. One piston is sitting higher then the others and there's a bent conrod. Took the plugs out and u rock the engine and can see water in cylinder 3.
Insurance covers it tho. Damm sr20's
How's this.
Hydrolock, it happens. Luckily his insurance covers him, always wondered about that
That sounds a bit weird to me. The airbox has a hole on the side for intake, and the box is pretty deep - so it should easily be able to drain out or at worst sit at the bottom. The N14 airbox works opposite to skyline one too - with air coming in the bottom and into the engine through the filter at the top, so I would have thought it would be pretty hard to get hydrolock?
Never had any issues in my N14 - it used to run a pod, gone back to the panel. I drove it through a semi-flood in Melbourne a few years ago when was a foot of water going across the highway - handled it perfectly (was using a pod filter back then).
how do i find the correct KNURL diamater for extended nissan wheel studs, M12x1.25 to suit C34 Stagea ?
I bought 20 "Ichiba-brand" 50mm long studs, came with 13.75 knurl - wont fit
Now ordered 20 more with 12.75 knurl, got to wait another 3 weeks till they arrive to see if they fit.
getting to be too expensive to keep "guessing" the size.
Ive measured a used one today from the rear and it seems to be around 12.5mm knurl diameter....... Im hoping its similar to the ones Ive reordered just now 'cause they are 13yrs old & used?
confused :P
confused :P
hey mate: try Jap Import Spares. they sell 10 studs for $40 and we bashed them straight into the drift car
thanks
Ive paid for this second set already, $100 del.
if these dont work will definately try J.I.S. - cheers
oh, I torque them on with a nut rather than bash them on.
got to grab a nut to undo the wheel hub bolt on rear LHS - cant insert new studs due to the parkbrake setup. nut must be 34 or 36mm !!
now I need to see what nissans use 13.75mm knurl - possibly GTR/navara/patrol/"insert Nissan model here"
Guest
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
