  • Replies 14.2k
watching a doco on future weapons. The USS Dwight J Eisenhower (Aircraft Carrier) was recently overhauled, now has 2 nuclear reactors and can stay at sea for 25 years. The Super Hornets can go for 40% longer, and the weapons are connected to the pilots helmet. They have a heads up display, and it aims the missile wherever they turn their head, and fires with a nod of the head!
*nods head
And aircraft carriers now sport anti UAV/missile laser systems. Cool stuff
And they have a 'heat weapon' getting deployed to iraq at some stage for crowd control - basically a big microwave oven mounted on an APC
-D
-D
or a humvee. theres also a version small enough to loosely be described as squad portable. its called an 'active denial system' or some such.
Looking at new steering wheels.. Ugh.. Like a woman shopping for new shoes..
Always loved the Nardi Classic I got when I bought the car. gonna have to get it retrimmed tho cause the leather is worn to buggery
-D
yup. got a nardi torino on its way for the s14... already talking about swapping it for a personal.
Have you considered re-conditioning it? Leather, being what it is, can quite often be brought back from quite hideous states to near-new.
I recently did this on both of my cars, and the 12 and 17-year old steering wheels now look near-factory.
tried that, they're too far gone unfortunately. needs new leather ;\ wont cost much to get done fortunately
-D
Ive still got the standard Type M steering wheel (same as GTR, but Skyline logo horn button). The leather on that is way gone aswell, will get it re trimmed soon - add it to the ever growing list of things to do haha.
I wish I had some before-after to show you guys how far gone you can still 'fix' a leather steering wheel. My N14 wheel I had written off and been wanting to get re-covered. I figured I was gonna re-condition/re-dye the R34 wheel, and so I'd give the N14 a go for a laugh, and I'm honestly stunned at how well it's come up.
I used the product from PPCCO - http://www.ppcco.com.au/kits6.htm
Damn cheap really, though lots of prep work with various treatments, sanding, filler, etc depending how far it's gone. I figured for $50 it was a cheap chance to have a go and see if it would work rather than forking out $250+ on the two wheels on my cars .. Eh, hey - each to their own. I don't mind trying a bit of DIY - figured I couldn't be in a worse position if I messed it up.
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
