  • Replies 14.2k
Pods = HAI = Fail
Air Box = CAI = Win
Put one of these over the pods and save a shit load of money.
Anyone know if 33gtr seat sits lower than 33gtst? Starting to get a bit annoyed with my head rubbing the roof.
It should be lower, they are lower than 32 GTST seats.
hmmm, ill give it a shot. if the kit gets here by friday, ill have 2 weekends to do it before
the rb20 goes in...
actually looking forowrd to gettin my hands dirty and doin some shit myself on this build, makes it more pleasing.
starting on ripping the 30 out today, perfect weather for it! :P
yeah was an awesome day, i dropped one out too
would anyone have an idea why my 20 would have a crossover pipe without a bov adapter?
Cefiro motor
no factory BOV
mine was the same :)
Still got that misfire mate?
Yup. Friday afternoon, a mate picks my car up from the tuners after having the belts tightened and the tuned slightly modified. Ask's me if he can take it for a spin round the block, i say yes. I get to his place after work to pick up the car...he tells me it is sounding weird, i start the car...it sounds like a WRX :P , i think either coilpack or sparkplug...ring a mate, and he sort of confirms it, and give me some soultions to fix it, they dont work.
Luckily my mate has a garage out the back, so i drive the car in, and pull out the coils and plugs. Coils look okay, plugs....are black and 1 of the 6 was moist. I swap the plugs around, aswell as the coils, put it back together...still the same - now i think about it, of course it would. So i leave it for the night.
Come back on Saturday with the stock coils and plugs that were in the car before. Change plugs first, start car...runs fine, rev it a bit, still runs fine. So i take the car home, all fine, take it for a spin once i get home, it stalls randomly 1-2 times, but other then that runs fine.
Take it to work today, runs fine, on way back from work, the car starts loosing power, dropping revs, and jerking, aswell as stalling at the lights 2-3 times. So i take it back to my mates place, where it is now until Tuesday, when i can take it back to the tuner.
My guess is either wrong plugs - put in Iriway7 first, then swapped back to PFR5G11
or
A Bad tune - Too Rich, not good with this heat.
or
Ignitors may be playing up in the heat.
It had been running fine until Friday afternoon, had gone about 1000km before then.
Cefiro motor
no factory BOV
mine was the same :P
ahh ok, cheers for that, hope your right haha, rb20de+t would suck.
wonder why it would have ecr32 written on the ecu then?? hmmmm
also, changed my mind on the turbo AGAIN.
did a dummy fit, i would need to run a spacer on the flange coz the compressor housing hits the manifold
before the studs are tightened, and i need an elbow made up.
i do however need a coolant line, the one that goes from the back of the block to the back of the turbs...
anyone got one lyin round?
need a full pic of the car with it on to make up my mind, but i bet it serves its purpose down the back straight of lala.
It looks bigger in those pics than it really is, its about the same size as Andrew's.
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
