  • Replies 14.2k
setup my bicycle and went for a ride just before
came inside afterwards, took the step down into the family room, leg didnt hold and crumpled to the ground !!!
left knee totally gave way
wowsers
This is a 12-13 inch pedobear plush toy for sale!
He is the pedestrian bear, see him run!!!!
he is made in his classic running pose
it is made to a high quality and could be a perfect gift for children ;)
:D
Goodmorning!
How tough is the scruteneering on tires at Mallala?
.. Also, do you have to wear gloves and do your shoes need to be leather?
I am awere you are to wear flame resistent clothing from ankle, wrist to neck... I dont want to rock up and not pass because shoes and gloves or whatnot.
Thanks!
Goodmorning!
Thanks!
I am not too sure, are you asking about the SAUSA track Day? I suppose as long as it's road worthy, It's fine. You need a Helmet, and a long-sleeved top - I wore a White Boiler Suit last time ;), and just some sneakers.
Hey Andrew, I found you a new Ban Stick :P
Guest
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
