that sucks to hear Brendan. Wish I did have time to drop by yesterday. I'm at the hospital atm. Slight training accident. Waiting for xrays. :D
ouch - hope you are ok. glad you didnt come over tho as I wasnt home :) - was wired up to a cardiac machine at the hospital being fed "heart slow down" drugs
  • Replies 14.2k
yeh I know
4 weeks ago I wouldnt have worried about it - state of mind at the time, but now more positive after seeing headshrink / new antideps so figured I better get to the hospital
always had a heart murmur (faulty valve) and an irregular heartbeat but never been concerned about it, more on the mind re: knees
was what youd call a 'small' cardiac arrest, perhaps stress as Ive been stressed out with lose of house, marriage breakup etc
seems my heart is irregular like its got a gummed up spark plug, not sparking correctly
they can go in and cauterize areas where the electrical currents are 'shorting' and fix up that way, so tests to see whats up this week
keep thinking positive dude. with any luck you'll bounce back well from all the dramas lifes got you in at the moment
remember, whatever doesnt break ya only makes ya stronger!
-D
I'm guessing something was changed because i now see the first post of a thread on every page of that thread, How do i turn this off as it is pissing me off.
click 'options' on the top right corner of the thread and click 'standard'.
soooooooo
Ive been in hospital, cardiac unit
had a small heart attack friday arvo
out of hospital now but out to cardiology specialist unit for more examinations soon
heart was over 200bpm for half hour & trying to come out of ribs Aliens styles, left arm went dead, then 130-190bpm for 24hrs
feel pretty ratshit now
anyways, yeah
fullon
yeh I know
Far out Tangles, everything that life can throw at you has by the looks of things......time to look up at the big fella in the sky for some answers me thinks.
Hope all goes well for you bud. :D
thanks guys for the wellwishing - REALLY appreciated, without doubt.
can only go UP from here!
mentally feeling ok - good in the head to be honest, chest is sore this arvo. rest time soon after some chow
then await flinders cardiac unit to call me tomorrow for appointments, probably drop in to GP to let them know the go as well
Guest
    • Don't think that can fit in physically. Are you referring to this?    If it happens again, I'm going to get the nismo ones.
    • I bought the 1/18 scale celica and nsx from Justin and they are very detailed and good quality. I will definitely be interested in others in the series as they come out
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
