  • Replies 14.2k
Yeah no shit hey. Trying to find out about catch can setups/ oil mods for some piece of mind and just when I get some useful info someone two posts down trashes it.
All I want is a lightly tuned reliable GTR.
  • Oil mods like which catch can, relocator and oil cooler
  • Front pipes (No I'm not going to AM Performance
  • Pods or panel filters
  • clutch, ebc, injectors, cams, fuel pumps.
Too many options, too many chances of buying a brand thats not going to work well.
It's simple, there's ASSLOADS of recommendations out there. Easiest way to pick what works, go to the RB26 dyno thread, compile a part list, work from there. That way you know what works and what doesn't.
As for your list...
[*]Oil mods like which catch can, relocator and oil cooler - JJR Autech catchcans are the trick, simple, cheap, easy
[*]Front pipes (No I'm not going to AM Performance) - If you're not going to listen to heaps of people recommending you see Andrew, I won't answer this, he is cheap, does quality work and his service is second to none
[*]Pods or panel filters - Standard air box is good for 400atw, it also lets a shitload more cold air in through the air guide, do the math
[*]clutch, ebc, injectors, cams, fuel pumps - Clutch; a nice twin is my opinion but that's personal preference. EBC; anything like the Profec B or the Blitz SBC. Injectors; 700cc Sards, straight drop in, easy as (although not needed if keeping standard tubos). Cams; not needed. Fuel pump; I prefer the Nismo for straight drop in but you can get by with an 044 or 040 Bosch
There you have it, a nice, easy, reliable part list.
I pretty much agree with everything that Heslo said.
For an oil cooler get one that sits in the brake ducting rather than in front of the radiator.
As for cost buy from Japan - Nengun, Greenline, Perfect Run, Import Monster or RHD Japan. With the current exchange rate against the greenback check out some USA sites as well and see how they compare.
There is soooo much info on what to do with an RB26 on SAU that you can get lost but you will soon figure out who knows what they're talking about. Most of the oil mods won't happen until you open the engine so start saving for it. Until that time stay off the rev limiter and put an extra litre of oil in for track days or if you intend to do some launches.
:P So Chad, whats it like to drive a 300kw monster on the road
Entertaining! Just make sure you have good tyres, I'm running crap street rubber atm and the hills scare the crap out of me. 3rd gear plus boost = sideways, even 4WD does not help :P
may i ask what rubber? kumho's im guessing? have u ever tried the toyo t1r? if so, how does it compare?
-D
any one had any experience with fitting these?
i want to run it with this
in one of these.........
fuel tank in there atm hasnt been used in 3 years, so i hate to see the shit in the bottom, also
need to replace fuel pump anyways....
from what ive been told craig, you'd need a surge tank with that setup as well
the only fuel cell ive seen that doesnt require that is a polycarbonate model from autosport, which im purchasing for the 31 for circuit
-D
Think of tyre brands most people haven't heard of before, I never buy good street tyres, i just use second hand crap. It makes driving more fun :P
iced cofee?
correct. well played.
sigh, dont get me started on IC atm..... coles have them for $1.44...
so when i did shoppin thurs night, i bought 15 of em
saves me buying one a day at 3 bucks....
in theory, they should have lasted me 15 days right?
wrong, i have one left.
and f*k it ima drink it nao
Hey Craig, Trent replied in that 17C thread you started in the Forced induction section, Seems it's a bit laggier than first thought with full boost (21psi) @ 4800RPM. That makes it as laggy as a TD06SL2-20G which would put you over the 300kw mark. I guess the old tech' compressor wheel isn't as efficient as the new stuff.
Edited by D_Stirls
Yeah i'll take it, i'm planning on buying a stag' next year so i'll either use it on that, or clean it up, put a kit through it and see if i can make some money selling it on NS, here or on Ebay
Edited by D_Stirls
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
