  • Replies 14.2k
you'll need the z32 after you hit 300kw tho... or go for the more expensive nismo afm
speaking of z32s, wheres the cheapest place to get em from, with the plug?
-D
Granted the extra 15mm of the Z32 over the standard size Nismo body may make a difference but not as great as what you would expect cause they have similar resolution and the Nismo bolts straight on with no extra wiring......I'd be ditching the standard restrictive GTR piping if you have a few spare $$$ and go for some hard piping.
Also, PowerFC has a default select feature for the Z32 to get you started whereas manual imput is required for the Nismos.....not an issue unless you're tuning it yourself.
Suppose it boils down to price & personal preferance at the end of the day.
All good points Pete. I myself went the Nismo route, firstly I got them cheap, second, they are direct bolt up, no mods required and I don't like molesting looms and third, if you're really sneaky you can go through regency with them on. Z32's; no chance
Anyone got any ideas how to remove a Vspec decal from the boot lid without fking the paint?
Prepsol, or a thin nylon blade like we do at work (cut down ice cream containers work too)
Prepsol won't hurt 2-pac but will acrylic.......just don't use thinners, LOL :)
prepsol or wax and grease remover shouldn't have any affect on acrylic, but yeah thinners is a big no no.
dammit u guys got me thinking
i was gonna go nismo till shane got me thinking about the diameter
and yeah I wanna keep it as regency friendly as possible.
i dont have a powerfc and wont be using that, instead ill be getting a nistune daughterboard for my ecu
just wish the nismo afms werent so damn expensive
-D
-D
Be vigilant... I got my AFM's for under $600
yeah ive seen a few places with them for that much, but ive also seen a pair of z32's for the $300 mark ;\
nismo is probably worth the extra $300 tho
-D
5.5 hours til i have a beer in my hand...
... and 29.5 hours til my next day off begins (if all goes to plan).
jake, you should be at that skanks place giving it to her, no excuses.
Edited by scandyflick
Guest
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
