R33... Rb 25/30 Inside
Nissan 95 R33 Skyline GTST
Engine:
Motor has only done 2500k's since full re build.
Fully balanced
Mahal Pistons
ACL race piston rings
ACL race bearings
ACL multi layer metal head gasket
RB25 oil pump
OS Giken twin plate clutch
T70 turbo
6boost style steam pipe manifold made by GARAGE7 (makes for a mean sounding RB)
263rwkw on 12psi
Cooling:
600x300x76 cooler
52mm alloy radiator
twin thermo fans
Interior:
fixed back race seat
dished drift steering wheel
in dash mounted oil pressure, water temp, and boost gauge's.
rest standard and very clean
fuel system:
walbro 550hp in tank pump
malpassi fuel pressure reg
wheels:
G-Max 18x9.5 all round
body:
needs a little work on rear quarters from big guard flaring and roof fading.
Suspension:
Tien fully adjustable coils (7kg front and 5kg rear springs im guessing)
JIC Front camber arms
adjustable rear camber arms
could be more that i have forgot but just com and look at the car. drives awesome! NO JOY RIDERS!!!!!
will come with 3 months reg
$14,500 ono or will swap
im not sure, i have been pulled over twice now and havent been done lol :D
OHH hahah nice pic
but what is on the car that will send it to regency?
im keen on the car but i wont get $$$$$$$$ till end of nov i think :banana:
so if its still around then i might take it off your hands but i dont
wanna get pulled over and go straight to regency :D
:banana:
Edited by Pepsinator
OHH hahah nice pic
im keen on the car but i wont get $$$$$$$$ till end of nov i think :P
wanna get pulled over and go straight to regency :(
:down:
well car actually passed regency around 10 months ago, since then, the rb25/30 and hightmount etc has been put in, and also the coiles and adjustable stuff..
Who did the engine work?
Chris Milton (Miton Engines)
max of 2g cash. the ute is 2.7ltr petrol, manual, 74,000km, exellent condition, has been lowered 3" but still at reasoable hight for work ute. Is the skyline engineered???
engineered for? it was engineered in qld or nsw for coilovers haha.. :P
engineered for? it was engineered in qld or nsw for coilovers haha.. :down:
ha ha yeh i meant engineered for the motor? r u interested in the ute?
unfortunatelly motor has spun a bearing... :P
isnt that big of a deal, but will sell alot cheaper as is, or if i get some cash up soon (after i pay my mate back :P ) lol
il be chucking some new bearings and shit in.. :D
 Share
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
