fair enough...
thanks for that info...im just trying to see if there is a way around not having to take the motor out, but its not looking to good atm.
Simple, don't take it to the track. In daily street driving the engine will last pretty well, but trackwork will kill it quick.
Baffled sump extension generally means engine out unless you really know what you're doing and have little monkey hands.
Oil pump is usually an engine out job too as the sump has to come off.
Another thing is, you talk of leaving the engine bone stock minus the oil pump, what oil pump are you looking at putting in? an upgraded/uprated aftermarket oil pump is going to mean you will also have to pull the head off to put some restrictors in.
OR
Run a catch can and an extra litre of oil and start collecting all the bits you will need for the rebuild :woot:
Upgrade to "better oil pump". This mod will improve oil delivery to the moving parts than present pump is capable (of). As I read it in the threads, oil problems are from poor gravity return to sump via standard oil return paths from rocker/cam dept., therefore more efficient pump is just going to accentuate existing oil return problem. (pump more up whilst allowing standard amount to return to sump)
No doubt you are aware of this but.
My 2c
GW
PS: I have sump baffle plate (Nismo from memory) & oil restrictor in head. Not tracking my beast, just a little peace of mind.
What they said! an aftermarket pump will only increase the amount of oil going to the head
problem is going down not up!
Happens on all 26s not just early 32 GTRs with the short crank collar
yer I see your point... but is kind of hard not to take it to the track if that is what I bought it for.
My 2c
GW
yer I am aware of that, but cant hurt to inforce the point hahaha.
I am going to try and make a oil return system... im pretty sure I can get the oil back into the sump fast enough, but the only problem is that im not sure if even though the oil is back in the sump, if when cornering the problem will still occur
OR
Run a catch can and an extra litre of oil and start collecting all the bits you will need for the rebuild :)
ok well i didnt know you need to pull the engine apart to change the oil pump... im not to familiar with the rb motors, i am more familiar with old holden motors, but totally different kettle of fish.
im thinking of either the nismo pump, or maybe something better...im not sure because i know that i will be revving it hard, and it will more than likely see the limiter a few times... will the nismo cop the punishment?
but im gonna stick to the second option hahaha :( ... i want it stock to begin with, but more than likely i will build it with some more balls... when I get the time to build it.
yer I am aware that the pump just feeds it up... and the oil doesnt get back down fast enough... but I am only changing the pump because of how hard the motor will be revving, cause i dont want it breaking on me in a hurry.
as i said... im going to attempt to make an oil return system, whether it be gravity feed or pumped im not sure yet... but if it works I will post it up for all to see, key word being *if* :(
Have to pull motor to fit a new pump.
Have to pull motor to remove sump.
Slight overfill, and save the money for when it lets go, then either rebuild it or have another ready to drop in.
Adding another head return pipe is a topic under discussion, wether it actually does anything productive or not.
Edited by heller44
Completely different kettle of fish.
I'll give you a quick run down on how I am setting mine up, bear in mind my setup isn't a 26.. it's a 25/30 with hydraulic lifters and small cams, rev limit will be somewhere between 7500-8000rpm depending on if it's still making power.
RB25DE (R32) head, stock cams/springs/valves/lifters
RB30E block
Wiseco Forged pistons
Spool rods
N1 oil pump
RB20 water pump
ATI 1000hp balancer
6boost manifold
GT3582R
Turbosmart 50mm Progate
ASR gated & baffled sump 7L capacity
1.5mm restrictors in block (hydraulic lifters so not going smaller)
Enlarge standard oil returns by 2mm each
Vent from back of head to catch can
Cam breather vents to catch can
Sump vent to catch can
Mazda oil cooler with integral thermostat
After many hours of research and trolling through bullshit, I figure the last 7 items should take care of any oil control issues and keep everything well in check.
Another thing to consider is that my car is 2WD and will not see the same lateral loads a GTR will.
Essentially, you can break down the oil control issues into two main areas:
- Starvation due to too much oil in the head with not enough return flow
- Starvation due to surge
The conclusion I have reached about that is that it is actually a vent for gasses, not a drain. It's to allow the gasses that are pressurising in the crankcase an alternate route instead of the gasses fighting the oil flow up the factory returns.
So providing an alternate path for the gasses, enlarging the factory returns and restricting the feed to the head slightly, seems the way to go.
Sort-of my conclusion as well, but still not worth bothering about unless you are going the whole hog and pulling the motor, and while it is out doing a full build..
Exactly, my head is already drilled/tapped for it so I will be plumbing it up.
Another way to achieve the same thing is to just vent the sump (from above the oil on the drivers side I believe) to a catch can and run the cam breathers to the catch can aswell.
But as you say, these are only thing to do when building the engine. As we stated earlier, in the meantime the OP should just run an extra litre of oil and see how long it holds together :(
An oil cooler will help prolong the engine life if beating up on it on the track but you're still going to have surge issues that the extra litre of oil should help curtail, not perfect but better than nothing.
as i said... im going to attempt to make an oil return system, whether it be gravity feed or pumped im not sure yet... but if it works I will post it up for all to see, key word being *if* :)
Imports 101 sell an oil return system runs from welsh plug @ rear of head down into sump
That's the head vent heller and I were talking about, it's not exactly an "oil return" and it really needs the head pulled off to be installed.
The RB26 already has a means of scavenging the blowby gasses that accumulate in the head/block. It is the pipe & PCV (valve) that runs from that back of the inlet cam cover to the inlet manifold. Opens under vacuum (ie closed throttle) & sucks the stuff out into the motor & hence out the exhaust.
On the other side a line runs to the suction side of the turbs (from memory). It is this one that sludges up your intercooler & has oil dripping out your BOV's.
Alot of people block both up when fitting a catch can - not the way to do it at all.
For what it is worth (not much) I have run an R32 R at Wanneroo & elsewhere for some 5+ years. On R comps. Originally an 89 & latterly a more recent model. Other than filling the thing up with 5 litres of oil I never had a problem with the 89 version. For the 94 I had fitted a sump baffle & a Nismo oil/air seperator. The only problem I had with that was caused by a stuffed PCV.
In short it is not the problem alot of people make it out to be.
As for failed oil pumps I strongly suspect alot of them can be traced to stuffed harmonic balancers.....Yes the 92 & on models have a better oil pump drive which is absolutely worth doing if you are up to your elbows in RB26 entrails. Yes the oil restrictors in the heads are worth doing if the head is off. But neither are mandatory.
+1
There's no point spending bulk dollars on a nice strong rebuild and then putting the +20yo harmonic balancer back on.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
