so i have decided to wreck my r33 instead of fixing it after crashing it. everything for sale is in good condition unless stated otherwise. listed below is everything i can think of but if you need something not listed pm me or call on 0419028565.feel free to make an offer but im not in a hurry to sell so dont bother low balling!! cheers, Luke
r33 gtst 1994 black s1 auto
engine stock-1000
gearbox auto-700
front subframe-250
steering rack-100
front passager seat-100
rear seat-50
pedals-50
passenger & drivers door-120 each
spoiler and boot-200
seat belts-100 the lot
tailshaft-100
brake master cylinder/booster-100
front 1/4 panels-120 each
apexi n1 dual cat back exhaust system-300
loom-100
tail lights-60
starter motor-40
speedo cluster with 76k on the clock-150
hey any pics of this stuff ur sellin big fella
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
