Hey guys! My name is James, I'm an American living in Japan and I've been "forced" by my Japanese wife to only buy Skylines. My heart is heavy and broken, for sure. ;)
So, I went to look at a 25GT turbo today and while I was test driving it, I noticed that the slip light came on "easily". The road was dry, the weather pleasant and sunny. It was not on constantly, mind you. From what I've read, that indicates a problem with the coil packs. And I had the coilpack problem before on my 25GT.
Anyway, I'm wondering if it's normally so sensitive and perhaps I just need some practice driving smoothly and slowly and perhaps some better tires... or does it indicate a problem.
I'm pretty sure I was at... 3-4k rpm in second gear already traveling at perhaps 40 or 50kph... hard to remember now... and hit the throttle pretty hard. Would that normally create a, um..., slippery situation in this particular or am I looking at a bigger problem? Or perhaps I'm being finicky... It's easy to be so when it comes to buying a used car!
I tried searching for TCS but I just get every topic that 666Dan has ever posted in :D I was just going to message him, but he logged off before I could finish registering!
So I'm very sorry if I'm asking a repeat question, but I honestly tried my best. I even looked in other forums... but I've been reading this one for so long that I felt akin to it. I was in ghost mode.
https://www.sau.com.au/forums/topic/291882-r34-tcs-and-slip-light/
Hey guys! My name is James, I'm an American living in Japan and I've been "forced" by my Japanese wife to only buy Skylines. My heart is heavy and broken, for sure. :)
I tried searching for TCS but I just get every topic that 666Dan has ever posted in :) I was just going to message him, but he logged off before I could finish registering!
hi i do have the same problem on my GTT when driving on freeway. It slipped sometimes eventhough i'm driving straight forward~ have no ideas what prob with it, might be coilpacks~
I suppose it could be them going out slowly. On the 25GT that I have now, it was a gradual process when my coil packs went the first time. Let to stuttering, rough idle and slow acceleration. The second time it was instant... and then I found out about Splitfires and then haven't had the problem since. Was pretty much planning on buying another set for the new 25GTt anyway, but first I wanted to see what others thought. I just hope that's the problem! Would hate to find out it's something else later that costs big bucks to fix :)
  • 3 weeks later...
Used to happen to me before on the freeway also. Would just ease on the throttle at 100km/h and the Slip light would go on.
Before I had crappy tyres all around and 17 x 8 and it still happened even though I have splitfire coilpacks.
I don't think it has anything to do with coilpacks.
Since then I have changed to 18 x 9.5 with brand new Kumho Ecsta KU31 and it has never happened again :thumbsup:
So I think it would be because your tyres aren't great.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
