hey guys just need help with one thing (sorry for being a newb) but i'm trying to find a hose to connect to my boost controller, it's that hose that's meant to come off the stock intercooler. thing is i have an fmic installed and there's no hose that comes off from it, any ideas which hose i can tpiece it off to connect to the boost controller?
*pic of which hose would be a great deal of help.
-thanks
you can tee it into the hose to the bov (hook it in using a T piece and a second piece of hose and not just stick the controller in the middle of the hose) but that isn't ideal. the best way is to get a nipple installed into the cooler piping, preferably on the pipe from the turbo to the cooler.
did you just install the cooler, or was it on there when you got the car? if it was already on there, find where the wastegate is currently getting it's pressure reading from (follow the hose from the wastegate back to where it joins either the cooler piping or the plenum) and put your controller in there
yeah the cooler was already there when i got my car, that's what i tried before (t-piecing the hose for the bov) the problem was it was overboosting so i was thinking that it was the wrong connection, what i've read so far is that the best connection is the compressor housing, can't really see with the heat shield being there, i've also read somewhere that you don't have to take the heat shield off to connect it, can you confirm that for me?
-thanks.
the r33 has no nipple on the turbo as far as i know (i have never seen one and i have pulled a stock turbo off) but i have seen people put them into the stock turbo (also some other turbos come with them fitted from factory). however i would just have one fitted to the cooler pipe that runs from the turbo to the cooler. when i first put on my front mount i was using the hose from the plenum to the bov and had spiking issues. then i put a nipple in the "hot pipe" as i refer to it and never had any issues with boost spiking again (well at least any that weren't caused by a faulty controller)
sweet thanks for that, will try it this weekend. A friend suggested that, was just seeing if there were any other alternatives but from the sound of your setup should be sweet.
-thanks
  • 1 month later...
I drilled a hole in the side of the fmic piping, and then tapped a hole for the nipple to screw into. Works fine for me.
@mad082, you mentioned that its preferable to screw it into the pipe between the turbo and the intercooler. I did it in the pipe from the fmic to the engine. What exactly are the downsides to how i did it? I only picked where i did because i figured it would be a more accurate gauge of the pressure going into the engine.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
