hey guys just need help with one thing (sorry for being a newb) but i'm trying to find a hose to connect to my boost controller, it's that hose that's meant to come off the stock intercooler. thing is i have an fmic installed and there's no hose that comes off from it, any ideas which hose i can tpiece it off to connect to the boost controller?
*pic of which hose would be a great deal of help.
-thanks
you can tee it into the hose to the bov (hook it in using a T piece and a second piece of hose and not just stick the controller in the middle of the hose) but that isn't ideal. the best way is to get a nipple installed into the cooler piping, preferably on the pipe from the turbo to the cooler.
did you just install the cooler, or was it on there when you got the car? if it was already on there, find where the wastegate is currently getting it's pressure reading from (follow the hose from the wastegate back to where it joins either the cooler piping or the plenum) and put your controller in there
yeah the cooler was already there when i got my car, that's what i tried before (t-piecing the hose for the bov) the problem was it was overboosting so i was thinking that it was the wrong connection, what i've read so far is that the best connection is the compressor housing, can't really see with the heat shield being there, i've also read somewhere that you don't have to take the heat shield off to connect it, can you confirm that for me?
-thanks.
the r33 has no nipple on the turbo as far as i know (i have never seen one and i have pulled a stock turbo off) but i have seen people put them into the stock turbo (also some other turbos come with them fitted from factory). however i would just have one fitted to the cooler pipe that runs from the turbo to the cooler. when i first put on my front mount i was using the hose from the plenum to the bov and had spiking issues. then i put a nipple in the "hot pipe" as i refer to it and never had any issues with boost spiking again (well at least any that weren't caused by a faulty controller)
sweet thanks for that, will try it this weekend. A friend suggested that, was just seeing if there were any other alternatives but from the sound of your setup should be sweet.
-thanks
  • 1 month later...
I drilled a hole in the side of the fmic piping, and then tapped a hole for the nipple to screw into. Works fine for me.
@mad082, you mentioned that its preferable to screw it into the pipe between the turbo and the intercooler. I did it in the pipe from the fmic to the engine. What exactly are the downsides to how i did it? I only picked where i did because i figured it would be a more accurate gauge of the pressure going into the engine.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
