  • Replies 42
^ this is what all of the 33 and 34's I've plugged in to have had, supposedly 32's also have the same connector.
Correct. Nightcrawlers R34 GT-T had an OBD1 connector, which surprised me as I was almost sure that all 34's had OBD2
Check under your dash's fuse area, that grey connector should be right near it
-D
https://www.sau.com.au/forums/topic/291893-ecu-error-codes/#findComment-4879201
Do u know how to clear them nick? If so what suburb u in and how much?
The software I have has an option to clear air bag codes, I've never had an air bag error to test it though.
I'd be willing to give it a shot, Highbury after hours or Frewville during my lunch break, no charges :down:
https://www.sau.com.au/forums/topic/291893-ecu-error-codes/#findComment-4879420
Wow, which software is that? Sounds like it must be CONSULT2 compatible to hook into the ancillary ECUs - unless its just OBD2?
Generally speaking most of the software out there (non-commercial) will only do CONSULT1 which is fairly limited in what it can talk to and do. On most cars I've played with on CONSULT there are quite a few other ECUs available via the bus, but require you to use the CONSULT2 protocol, which isn't very well documented (if at all). When you do an initial query, it'll list all of the ECUs you can talk to... (Seem to recall 'EF' is the main ECU, but there's also stuff like SRS, TCS/ABS/HICAS, AT, etc)... Anyways ;)
https://www.sau.com.au/forums/topic/291893-ecu-error-codes/#findComment-4879496
Does anyone have any pictures of where exactly the OBD port is located on a 32 GTR? I've looked all under my dash, near my fuse box, everywhere... but can't find it!
And the net only shows the actual plug but not exactly where it is :)
Fusebox Above your right knee, port is above the fuse cluster, to the left.
-D
https://www.sau.com.au/forums/topic/291893-ecu-error-codes/#findComment-4879761
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
