Well after a thorough investigation i am almost 99.9% sure that my harmonic balancer has moved on its center and is now showing a 5* advance at TDC.
Meaning when the 2 cam gears line up with there respective markings on the backing plate, and when the dot on the crank cog line up with its respective mark on the oil pump and i slide on the HB, it reads about 5* i.e on the second line from the left. (keyways are good)
Does this mean when using a light to set timing i use this second line as "0" degrees???
The engine is a R33 RB26 so instead of the 20* being on the 5th line it would now be on the 6th???
Thanks.
https://www.sau.com.au/forums/topic/291918-setting-timing/
The belts probably just skipped, check your idler/tensioner is still spinning freely. Then check belt tension is within spec. I would get the bottom end on TDC then start all over again.
I have never seen a busted key, even on rb30's with 600,000ks.
If the front bolt is within torque spec then it simply should not happen.
Edited by James_03
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4879351
you guys are not listening to or understanding smell.
mate i know exactly what you are saying. yes you do what you suggested in 1st post...but if it were mine id source a new balancer. I have a good unit here if you need one
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4879363
  smell said:
Finally.... someone who understands english..... :)
Thanks for the offer but i'm on the next side of the globe!!!
Can a R32 GTR balancer work???
Yeah, true. It's impossible to send things to the other side of the world.
Paul you are a silly man for suggesting such a preposterous thing!
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4879825
How many ribs does the front pulley have? and does it have a thick divider between the PS and AC pulley or a thin one?
Sounds like you have the balancer off a series 1 R32 GTST. Either way, if it has moved, you need to replace it or you could kill your engine.
If it hasn't turned, then yes, you just take your TDC mark from that second mark
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4879834
The balancer marks never line up on the factory balancers.
I think you should either buy a new balancer or just use the mark it lines up on as tdc.
I would be very surprised if that balancer had rotated on itself unless it came off a drag car. They are one of the best factory balancers out there and I'm yet to see one that has turned. I've seen them get small cracks in the rubber on the back but not turn
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4881128
  smell said:
Can't find any info....
Is the R32 GTR balancer the same as the R33 GTR???
no they are different. The offset is different due to the different alternators used.
I found this out on my 33GTR. Had to use a 32GR balancer to get the belts to line up.
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4886224
Did u mean u had to use the R32 gtr alternator along with the R32 balancer for everything to line up????
It would be nice to see some pics of the 2 GTR balancers side by side. Anyone?!?
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4889639
  smell said:
What do u mean by this?
Are u saying when the engine is on TDC the balancer does not necessarily have to be on the 0* mark????
What I am saying is that you probably don't have the crank lined up EXACTLY with the mark on the oil pump, so if you lined the balancer up with the 0* mark then the cams are likely to STILL line up anyway. The crank mark on the gear is the hardest to line up properly because you are always looking down at it from an angle so it can always be off slightly.
What I am also saying is that you are frigging around with it and being waaay too paranoid about 1 or 2 degrees on the balancer when chances are when the thing is running and you put a timing light on it, it will be moving around 1 or 2 degrees anyway so it's going to be practically impossible for you to get it right to the degree anyway.
If the balancer is in good nick, then use it and drive the car. If not, then replace it with a good aftermarket one. If you can't afford the ~$600 AUD for one then save up, buy one, and your problem disappears.
That is, of course, if there is even a problem there to begin with....which I think there is probably not.
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4897327
The crank is lined up EXACTLY with the mark on the oil pump... i used a mirror to make sure it lined up properly.... even turned the engine a million and one times to get all three white marks on the belt to line up too!!!
I posted the pics of the balancer also.... what do u think of its condition???
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4897346
Is this the first time you have checked it? or have you been monitoring the movement?
It might be a silly question but what type of timing belt are you using? and how old is it?
If you are really worried about it why don't you use a dial indicator and check when you piston is at TDC to verify your marks etc? then you may be able to adjust your marks on your front cover to suit exactly.
Have fun.
https://www.sau.com.au/forums/topic/291918-setting-timing/#findComment-4897448
