The crank is lined up EXACTLY with the mark on the oil pump... i used a mirror to make sure it lined up properly.... even turned the engine a million and one times to get all three white marks on the belt to line up too!!!
I posted the pics of the balancer also.... what do u think of its condition???
That mark is not perfectly lined up.
Turn it another degree clockwise.
If you are really worried about it why don't you use a dial indicator and check when you piston is at TDC to verify your marks etc? then you may be able to adjust your marks on your front cover to suit exactly.
No need for all that.
I PM'd Smell a while back to find TDC via a piston stopper and remove all this balancer guesswork.
Time to move on.
how about posting that info here?
Not really the right section but....
A piston stopper is nothing more than a means of stopping No 1 piston before TDC, usually a modified spark plug or similar.
Take the usual precautions regarding cleanlines etc.
Rotate the crank until the piston touches the stopper and mark the balancer (or your degree wheel) against a fixed point.
Rotate the crank the opposite direction until the piston touches the stopper and mark the balancer against that same fixed point.
TDC for No 1 will be halfway between those two marks.
The larger diameter of your degree wheel improves your accuracy but even the balancer's diameter is better than the tiny crank gear.
Well guys some new info on this.....
I fabricated and used the piston stop as grigor suggested and i must say it worked a treat!.... so much so that i realized that my balancer has NOT rotated and the orange 0* mark lines up at TDC mark on the backing plate when the engine is in fact at TDC.
So now if i use the orange 0* mark on the balancer to get the engine to TDC none of the marks, ie. crank neither cams line up with their respective marks on the backing plate.... they are all just a tad too much clockwise.
I don't' have pics of the crank, but the reason why i say it would be a tad too much clockwise is because when all three dots line up perfectly including the three white marks on the belt and when i slide on the bal it reads about 4-5* advance , so obviously when i now turn the bal to get it back to the 0* mark all three gears would have rotated clockwise some.
Have a look at these pics with the balancer set to 0*
Notice the mark on the backing plate is just off the tooth of the gear and not dead center
Intake
Exhaust
TDC
I even took it to a mechanic and he was puzzled as well to see when he lined up all three marks and put the bal back on it read 4-5* advance..... so i know i'm not crazy!!!
Yeah and the backing plate is mounted on rubber inserts so it could be off too. And the lower timing cover could be off as well as it's in rubber washers too.
You should go and buy all new parts and fit them, that way you can find out that you are making a huge deal over nothing and none of it will matter when the engine is running.
Also, take the shot of the cam gear from front on, not at an angle. Make sure it's parallel. Taking shots from an angle distorts the ability to view it for every degree it's off. Considering you are chasing 2-3 degrees then this is very important
I am definitely not a mechanic but all rbs i've changed timing belts on before had all timing marks lined up spot on and the bal on 0* at TDC ..... i mean Nissan would not have but those marks there if they didnt intend on you to use it would they????
My thoughts, as sent to Smell, are that he’s now reached manufacturing tolerances and anything closer will require adjustable cam wheels.
Obvious stuff like a decked block or shaved head have been eliminated as the cams would have retarded not advanced.
A thicker than factory head gasket also seems unlikely.
Can’t recognize the marks on the cambelt but I don’t like thicker than factory aftermarket cambelts as they advance cam timing due to the extra thickness over the idler.
I dug out a few Nissan belts and the root of tooth to back of belt is constant at approx 2.3mm
However the top of tooth to back of belt varies from 5.2 to 5.6mm.
15thou mightn’t sound like much but it doesn’t take much extra at the idler to advance the cams.
Gates belts are another story.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
