Hi guys,
Have a track day coming up on 25th Oct and trying to sort out some tyres.
KU36's are not available anywhere in Oz in 265/35 - Not in the warehouse, and i think i rang about 10 places yesterday around Melbourne but no one keeps that size in stock.
Ideally, i would want to run 265/35/R18 but have been told i could run 245/40 if i wanted to, and the car would be 5mm higher, no big deal.
Or i can get 265/35 in KU31's, as they are available.
The car is not driven every day, and realistically will only see about 2-3 track days a year. Problem is though, my bridgestones at the moment are not coping with the 285rwkw. I'm 99% confident it isn't suspension issues as i have pretty much everything in that department. Front rear camber kits, pineapples (max anti squat), adj swaybars front rear, bilstein shocks, whiteline springs. And just recently had the boys at Traction Tyres install a few things and give her an alignment, so i think the suspension is about as good as it's going to get at the moment, which only leaves the tyres as the problem with no traction when on boost.
The KU36's sound great and are obviously priced very well, but what would the better option be? 245/40/R18 in the KU36 or run the full 265/35/R18 in the KU31's?? Is there are HUGE difference between the 31's and 36's?
Or not worry about it as i'm likely to have traction issues regardless unless running a better tyre?
I guess i could always turn the boost down :down:
cheers,
daniel
https://www.sau.com.au/forums/topic/291923-ku31-26535-or-ku36-24540/
tried all forums, practically all drivable kumho dealers in melb as well.
no one HOLDS stock of that size, it's order in job. The warehouse, kumho, has no 265's. So doesn't matter who i call or pm or email, no one can get them until after christmas.
so now i need to decide if i should get some 245/40's in the KU36, or perhaps 265 all round in the KU31. I maybe go some Federal 595's SS or RS-R, or some Falken RT615's or maybe just put 2 good tyres on the back, and leave the bridgestones up the front?
not sure which way to go
Ah, i was under the impression O1G was bringing them in themselves, as A tyre shop i spoke to told me they were selling them for less than what they could buy them for...
I personally would go the slightly thinner better compound Ku36 if on a budget, or look at another tyre if you want the size... RT615's are meant to be decent
What width is the rim?
18 x 9, all four (R34 GTR rims)
265/35/R18 standard. But Traction Tyres said i could go 245/40 if i wanted, don't know how much of a difference it would make though.
O1G might be direct importing, but i don't think even the factory is producing any 265's at the moment it seems. Maybe that's why not even O1G can get them.
the 245's wouldn't look weird would they? i'm guessing you wouldn't be able to tell just by eye-balling them... don't know though
I run a 235/45 on my 9" wide...
yeah, i think i'm fairly sold on just going 245/40 in the 36's. Price difference is just too great to try and hunt something in 265.
From what traction tyres told me, 265 is about spot on for 18 x 9 and for track work the furthest you'd go down would be 245. And obviously not go up anything. If it was purely for street, i'd probably be a bit more flexible, but because i know they'll see track time i'm keen to stay within safer limits
my 235/45 does not have noticeable stretch. It doesnt quite use the rim protector on the ideal angle, but it is FINE... I can give you photos tomorrow of how MINIMAL the stretch is.
Supposedly 180rwkw... really should put my EBC in and wind it up ey . So I guess Can't really compare given you have ~100rwkw more.
I dare say my car is a little lighter and stiffer than yours though(with a 2way), and I wouldn't say I struggle for traction. With shitty neovas, I did. If you are going for max traction on a budget, maybe go 245/45 for the extra sidewall? and its cheaper. A light stretch on the front will also feel better, and be cheaper. I assume you are keeping an eye on the wallet given your options. PM Ash and ask him what Tyres he was running, he had similar power to you with no issues, now has more I think.
The 45 series is cheaper and has a higher load rating, something to keep in mind.
235/45/17 KU36 $164.00 94W
245/40/17 KU36 $215.00 91W
245/45/17 KU36 $202.00 95W
put the 245's on mate... that's the right size for a 9 inch rim... I ran 235 on my old R34 GTR rims and they were fine
I was looking for the KU36 in 265 for my 10 inch rims but was in the same boat as you so went for the 275... seem to be an okay tyre, pretty good for the price
best thing you can do for traction is a good mech diff... made a world of difference on my old car
245's are fine on 8 or 9in wide rims but the Kuhmo's aren't a true semi slick tyre.
You mentioned going to Traction Tyres, the owner Andrew is away as he is unfortunately being treated for cancer but the guys there know what they are on about and they don't rate them anywhere nearly as highly as the true semi slicks.
Falken RT615's are the same as the KU36's designed to be more a really good street tyre. You need to get a set of Falken RT215's or RS V04's if your looking for a really high performance tyre in that price range, I run RS V04's and so does Jim Richards and he has previously won Targa Tasmania on them.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
