I drove to Bowral for the w/end - saw so many stinking skylines but only 1 recognised my car and flashed/waved and that was a S1 R33 Gtst w/ GTR front bar, plates FLYXXX (X = something i cant remember)
Saw 2NTYSU in bowral, nice white S2 with white rims, another white S2, a wine red S1 on the way home on M5... saw tonnes more, cant remember them all. The car scene in Bowral is pretty impressive.
Christian
Christian
woohoo somebody finally spotted me!
its a trust copy front bar btw :cheers:
I saw somthing... It looked like a series 3 R31 rear end had badges on the back that said 'turbo' and 'Passage'. It was a 4 door but seemed not to have the middle pillars (is that the 'B' pillar?)
It was at Coogee on Saturday morning or whatever time I got there for breakfast.
Saw a nice lime green 32 coming out of Panthers around 2am Monday morning, and 1pm Monday a dark blue 32 (MIDN9T?) going up the M4 at Emu Plains.. heaps of others over the wknd as per usual these days..
Spotted R33 series 1, 2 tone 4 door on Princess hwy out the front of Tynan motors.
Plates: MIZ 25T with green p's
CAR: Has 18's, backs are dished and aftermarket BOV & Exhaust...
Was a very sleek 4 door....
Oh, was also missing a passenger side mirror... :cheers:
I spotted this car on Sat Night in Cronulla...... Remember because of the hanging mirror!!!!
Jono - what power you making now ?? Ummm if my memory is right (too many beers) - Ahhhh I don't even remember ----->
60rwkw is a great gain - NO A TOPS GAIN!
Well done mate :)
Now making 248rwkw's, good gain up from 188. Added Power FC, Cam gears and 2 pounds of boost (12 up to 14) :)
hahaha... well when you subscribe to a thread, you tend to keep checking when you get replies :( also got that thread via e-mail as well! ;)
also spotted a darkish 33 last night... around 11ish... thanks for the games from the m4 down silverwater rd :)
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
