Tommy: Nathan has worked on my zed, MR2 and GTR and done an excellent job on each of them at very reasonably prices.
He recently fitted my Nismo clutch to the GTR as you know and I was suitably impressed.
I've said it a number of times, but I think Nathan is one of the good'uns. He's straight forward, gets things done quickly and there is never any nonsense.
I'll give you a few examples.
1) I booked my car in to get the injectors cleaned. When I dropped it off he noticed it was idleing high: I said that I would also like to get the timing checked and reset. Got the bill, and he didn't charge me for the idle reset or timing check/reset. Sure they are quick jobs, but he has every right to charge for them.
2) A gasket blew on the exhaust side of my engine. I lived with it for a few weeks but it was getting worse. I rang Nathan on a Friday to ask him about some parts. Before I could even get to that, he offered to open up specially on Saturday so I could bring the car down and he could have a look.
When I said (feeling rather guilty) that I would give it a go myself, but needed a few parts, he ordered them in for me, suggested some others I hadn't thought about. I asked him if he could order in some of the annoying washers for the turbo oil and water lines: he gave me a bunch of them for free.
That's the kind of bloke he is, and that's why I always try and get any work on my car done there.
Lucien.
Well said Lucien - I find that with work its hard to get time to run around getting things done with my car and Nathan makes it all very easy.
With my clutch I dropped the car off in the morning at 8:30, jumped a bus to the city, cabbed it back at 5pm, car was ready with new clutch fitted and starter motor rebuilt, no questions, no surprises and a very reasonably priced bill.
Things like this make getting work done on my car so much easier.
I've only recently started dealing with him, and have had a few issues some injectors that he installed and supplied. (note. problems due to the injectors not workmanship). He's been understanding and patient with me and hasnt given me any impression that he would do a dodgy job.
He is the type of bloke who will make an effort to keep his customers happy. I'm sure if it was another mechanic he would of told me to go stick up my arse.
I will keep using him for things which are beyond me.
I was there this morning as well!
It was skyline city today. But he also had a Daewoo in there..... What the!!!!!!!!!!
Nathan is excellent. I have had both my skylines serviced/repaired by him. He doesn't over charge, He does things rigth the first time around and he is always forthcomming with advice. I have never taken either of my skylines anywhere else.
He is also super patient.
Thanks
Adam
Hey I know this is abit late, but spotted a black R33 with pink interior driven by a blonde chick 'HOTEE' heading south off hassle onto james russe 9:40am.
good to see more girls into skylines but can't say much about the interior.
hahah yogi they would no doubt be my old injectors.....which is a bummer since they were working OK when I pulled em off my car. :( Hope you found some decent ones.
BTW :werd: to Nath at Ghey Imports, he does a great job and puts up with my stoopid questions all the time ;)
I spotted AE07UG yellow 32 GTR today, not sure wtf it stands for? Also spotted Chris (RedX) down at Autosport Engineering and HGE002 at Kenthurst
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
