Official NSW Skyline spotted thread
CerealKiller
1967 Shelby GT500  :drooling:
Plates "ELN01R"
Could have been a replica but GOD DAMN it looked good!!!
Seen that too tosh, how damm gorgeous is it!! Sounds like its got about a 1000hp :cheers:
Seen that too tosh, how damm gorgeous is it!! Sounds like its got about a 1000hp  :P
I know I couldn't believe my eyes!!!! LHD and everything... very tough.
Yeh it does sound like it's got a few herbs under the hood ;) hahaha
I spotted BNR32R today near Narellan
rockin! that car is sweet. I saw one today too, HGE32R. Not sure what the street is called it's just of cobitty road and goes around and around. looked hawt...
I saw u few times in Chatswood. Once you were driving out Westfield car park with ur gf?
The next time u see me.. I'll be driving Integra Type S.. the Skyline is gone now...
Saw a couple of Skylines tonight
1. Sawakita on Epping Road near Epping station
2. Had a nice run with JDM-32R white R32 GTR, a WRX and a Soarer down Gore Hill end of Epping Road.
3. GTR-80Y in the city, burgundy R33 GTS-T.
Yes I was
Did you keep your plates? YAE-***?
Yes.. Integra Type S.. Its easier to drive and use less fuel + my R33 is getting old and problems seems to occur, so far I've spent over $15K to maintain that car over the last 2 years..
No WinK, I didn't keep that number plate.. the new one is AE-80-YS
lol ah..it was u!!!!
i had fun the WRX kept on teasing him...
everytime he comes up to me i bolt off give him a lil chance to get even with me and leave him again :D
hehehehe
white 33 pacific highway hornsby. going towards hornsby tafe. 11.14 am grey 32 out side hornsby station bus exchange thingy. 0015
dunno if the grey one was me or not... not sure... possibly
    • Meh. I "see" a typo above, that should have been "sell".
    • The clutch pedal has a procedure for adjustment. This can only be done after you are 100% sure the system is absolutely free of air bubbles. You must bleed the clutch master cylinder first, then the "separation pipe" which is the clutch damper line, then the operating cylinder as detailed in the service manual. Also, you must fully depress the clutch pedal between shifts. Just because you can't feel it grabbing does not mean the input shaft is truly decoupled from the crank. At high RPM clutch plates are vibrating and moving around, you need to give it the best possible chance of success. On the BCNR33 Nissan revises these adjustment procedures slightly but not by much: I would be careful with trying to play games with these adjustments. As for the Nismo operating cylinder they say a lot of things. In practice the twin plate clutch needs less movement on the clutch fork to disengage because the whole stackup of the flywheel + friction plates + pressure plate is much taller. Personally if you find that the clutch still disengages too high at the top of the travel I would try the Nismo operating cylinder. Make sure to follow the air bleed procedures.
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
