Fri arvo?
Spotted by SW20 again? You must be too stealthy!
Not long after that I spotted a 4 skyline convoy (had one black 34GTT) and another trailing 34GTT with P plates going west on victoria rd between powerplay and the gladesville bridge. Someone honked as they pass me but i was stuck behind a Tourak tractor and didn't react fast enough after seeing the first skyline! I pressed my horn late too but it didn't work. AAnyone know where to get a spare horn button? Mine's smashed mine to bits honking someone.
T
Yep, the black Honda Accor Euro is Stealth++
also JR34GT yellow R34 GTT with the Nissan Aero kit on Lane Cove Rd near the Comenarra Parkway
i think i might work with whoever owns that car, its parked outside my work everyday, but i have no idea who owns it.
Spotted CYIFLY near Auburn?
MARSS in George Street.
A Gold/Yellow R33 with a black wing wearing a SAU sticker on the quatre panel going through Chittaway.
A few grey R32's in the city. One pssching past a nice WRX.
Blacktown @ Midnight (Near Blacktown Hospo)
Black r32 GTS-T Sexy with bov.. not sure on numberplate
White r33 GTS-T White with bov.. RB-1337 Red Plates
Silver r33 GTS-T Tried to race us lol... 4KRUZIN
4kruzn was on a commonwhore with air bags
(glad i didnt buy it)
did CYIFLY used be on a green sprinter like 10yrs ago.
OFD-14L do you come on here?
Spotted TRD-33Y on cleveland street around 7ish on saturday, damn that traffic was bad.
Spotted TURBOS at double bay around 1.30am sunday with a ridiculously loud exhuast.
and two girls in a grey R32 GTST on cleveland street 2.30am ish dancing and singing in the car.
BTW, I was in a white R32 GTR ATI-33A
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
