Spotted Smasha's car near broadway/ultimo again.
You left your headlights on!!!!! Hope the battery doesnt go flat.!
Thanks dude.
James called in to my call centre to let me know :laugh:
I'd left it there for an hour with the lights on.. It turned over....... juuuust.
Thanks dude.
we were all talking about how to get ahold of you!!! LOL
LoL
It was quite funny, I just get this email saying someone called to tell us you left your lights on.
I was like... WTF...
Then James sends me a SMS saying "the supra tells you when your lights are on".
Big Brother shiznit.
spotter a hot R33 midnight purple
actually i see it everyday right next to my work
with massive BD4's sticker on rear window with white rims
very nice car
spool is very loud along with the bov....
if ur on here
then awesome car
i work next door @ highpoint....
nice rideee, very niceeee
spotted hot boy in dark blue r32 with 33 wheels on delhi rd nth ryde yesterday.....
Good to see you are on SAU, i saw you again today around 5:30 while i was waiting to turn out of a sidestreet onto the Pacific Highway at Lindfield.
I was in my maroon R32 4 door
Spotted a black R33 launching along the Great Western Highway earlier tonight, heading West past the intersection of the highway and Centenary Rd/Station Rd in Wentworthville.
I was too far back to see if it was a GT-R or GTSt, or what series it was, but it did have a GT-R wing on the back... Looked pretty clean, though.
ha!, so now you're stalking me?!?. i'll have to keep an eye out for you, how many other skylines do you have??.
hmmmm....
Teh Blitzy gets around................
AVO anyone????
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
