hey dif
Haha thanks..
Yea sorry i was abit spastic there.. lol.. so tired from after work.. yep it certainly is! how FILTHY was it!!! :)
Spotted a white R34 Gtt 4 door yesterday on atchinson rd mac fields at about 5ish pm?
I waved and he looked and me funny :S could be because i was in trackies :S
oh, spotted a white 32 gtst with racing numbers on the door - was yesturday - i forget where! mid afternoon sometime
my car :) I saw you but Wil didn't
I still haven't taken the numbers off from the last track day or washed my car since then :P
FAT-32R black r32 on Dunheved Rd thisarvo 5:30ish
was in the green excel.
and a yellow r33 on the crime investigation channel at blacktown station.
edit: also the green Stagea that works near me with #plates STAGEA
and the 2 toned silver r33 with 4stud wheels i noticed.
Edited by RSTME
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
