that was me.... :)
i did see the thumbs up.
Nice rims, nice sedan :/
Yeah thanks mate! Your coupe looks mint. I love the rims. I only put mine on yesterday. Do you have any problems with the spokes interfering with the rear caliper?
well there's about 3mm in between the caliper and the rim, and in the year that I've had them, no issues (except for gutters :/ )
i spotted my own r33 on Surveillance footage as it smashed through a shop and did two ram robberies. car was stolen two days prior. cops chased, but it got away. i found it last saturday but it was written off. :(:(
damn thats bad luck dude
That's F**CKED! ;)
Bill & Teds Bogus Journey :)
ohh yeah! :(
i spotted my own r33 on Surveillance footage as it smashed through a shop and did two ram robberies. car was stolen two days prior. cops chased, but it got away. i found it last saturday but it was written off. :(;)
awww.. that sux dude :( was it insured?
i dont even have that much clearance. are you running a spacer?
nup...
by 3mm i meant minimal room. haven't actually measured. You'll be right, as long as the nuts are tight, and your caliper doesn't move ;)
I understand that was an IMPULsive comment... but it's just wrong on many levels..
Much fooly sickness spotted in the city tonight.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
