Official NSW Skyline spotted thread
CerealKiller
think it was me
i drive a stock gtr
you went up to the freeway
nice to be spotted :)
Yep up the F3 everyday for tailgating fun by red P platers :)
Car looks noice :P
Also spotted a white 33 (S2 wing) on the F3 last night between Wyong & ourimbah exits Southbond about 9.30pm lat night... couldn't quite catch up..just noticed the stove lights ;)
spotted wtf 33r last night i was in my mates forrester and u wouldnt run. soft hahaha
Yay my first Spotted!
Ah is that who it was! I was half asleep nor the mood, plus I'm not in a postision to lose my car and licence it means job gooooone! What was the poofy run against the TX3?
i spotted him on friday night at thornleigh maccas... i should have gone over and said hey but i was eating :P
I saw your car there too. should have come up! I dont bite ......................... (hard)
Yep up the F3 everyday for tailgating fun by red P platers :P
then i'll c u round i do that strecth too much
Car looks noice :D
thank you it took me a year of shopping to find her and we are both very happy
shoulda... but i make an ass of myself enough without jumping into the middle of a group going "WHO OWNS THAT PIECE OF SHIT!?"
saw 2 skylines today... two that i feel like mentioning at least... both in chatswood...
one a silver 34... plates ** ** ** something... another a red 33... plates ******... the only reason im mentioning them is cause they flashed back :(
GET SOME MEMORABLE PLATES FFS! i dunno who the f**k you are :rolleyes:
Edited by DRD-00F
Saw 2 jillion Skylines last night on the way to Heaseman's Suspension, then another 1 million (and their owners, and, finally, another Stagea :):(:rolleyes:) while there, then quite a large number of Skylines today.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
