Official NSW Skyline spotted thread
CerealKiller
that's f**ked dude.. hope you got it sorted.. can't say i saw you tho :)
Yeh i was 2 cars behind you after you turned left onto george st, but couldnt get past the lights onto parra rd cuz car wouldnt move for me :P
Sam, it was parked in Franklin Street. Although I didn't get too good a look at it, I'm sure it had chromies (nothing too over the top, thank god) and a rear wing on it - I'm pretty sure I would have recognised your car even if it was from just a quick glance.
ah cool.. yeh def wasnt me then lol
spotted RUGAME next to me on king georges rd around 2:30ish, but i was in the xr6t again.
and a white 4 door r32 on princess h'way turning onto port hacking road, plates JCD- sumfin
spotted some dark colour 34 4door i think parked around the corner from me in the dark near the park.(Get a Room) LoL
and a silver r34 BBZ *** come hooning past me on Doonside Road
not even 5minutes ago.
spotted a few imports in the carpark on my first day at work today :)
also spotted caine at MAC center at lunch today... didnt get the chance to scream out or stop u.. i was going up the elevator wen u got to the bottom lol...
mainly s15's no lines tho :D
Edited by mass_iv
mainly s15's no lines tho :)
*clears throat*
Spotted Marsss on Parra rd near Petersham heading towards the city.
I was in the Hiace going the opposite direction, hahaa beeped at your for aaages..
yeah got the SMS.. as you can understand.. if a Hiace is beeping at me.. i ignore it with gusto... but i'll know next time :rofl:
y is it everytime i spot somone they're never a member of SAU?!? I've been meaning to actually send in my membership form/money but i've been out of work (its been really hard because my skyline needs some work done and i can't afford it) I think i've figured out y i haven't been spotted...because it looks like a piece of junk with bad paint...i just wish i had a decent looking 'line!
I think i spotted security today at lunchtime outside subway/oportos off canterbury/milperra rd
If not, it was a yellow 33, bodykit - plates started with auf i think
I was the guy driving the gunmetal 33 >_<
you'll find that alot of the cars here are a work in progress mate. mine being one of them. took me a while to get the paint sorted.
I was the guy driving the gunmetal 33 :)
yeah mate that was me, i saw you but didnt get a wave or anything so i didnt think too much of it. and when you see a bright yellow r33 you KNOW its me, not think :domokun: . my mate [username: vexed on here] was there too with the blue r33.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
