Official NSW Skyline spotted thread
CerealKiller
Yes i am from QLD, i was down in sydney for work this past week. and i spotted only one possible car, that was a Silver Stagea. em the road was a black one with with lines.... near the airport lol.
GO SYDNEY TRAFFIC....!!!
spotted a stagea at my work car park norwest - HGE ***. Nice AVS rims
lol must be the place to be spotted, thats twice in a week.
Didn't see your car there though? or did you get there early enough to park inside
hehe I get there at 8 so theres usually parking inside.
I didnt know it was your car and you worked there. what do you do there? i'm in office infra :)
I spotted a bayside blue R34 GTR a coupld of times in the city last week.
Also got flashed by a black R32 on Heathcote road yesterday. I think I flashed back but not sure if I pulled the lever hard enough.
Also saw the same white r33 3 times yesterday in various places. White guy driving, asian girl passenger. The first two times were unsurprising but to see them coming towards me again 3 or 4 hours later was a bit of a shock.
Spotted white R34 4dr with what looked like TE37's and FMIC going up Warringah Rd this afternoon about 4pm, looked nice and clean :thumbsup:
Hey Gengis, I'm running a project for logistics for the next few months...only started a few weeks ago :thumbsup: Is office infra part of IT? I'm dealing with a bunch of guys down there re prices atm.....
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
