Official NSW Skyline spotted thread
CerealKiller
spot this green stock r33 s1 everyday turning onto the cumberland from the hume at liverpool. around 845am., a middle aged bloke driving it. Also a white series 2 r33 with 2 young blokes on the same road
spotted black r32 gtr on showground road, #no plates were AUD-xxx i think at 6.35am
then spotted silver r32 gtr near castle hill towers same time, plates were BNR-32W
what u doing up at castle hill at 635am?
arent u suppose to be at school ?
haha skool..
left skool april 06..
my job office is at norwest buinesspark and we go around d hills area doin aircon installs
haha skool..
Well, I see you didn't learn much English at school.
AYY 56Q i think it was... gun metal grey R32 GTR on pac highway in waitara sorta... we were in the other 32 :( damn that thing looked fast!
hello if your on here...
and yes that was a chick driving... Jess, known on here as Sinful (plates are SINISTER... sort of...)
LOL @DOOF :) (sif sort of)
Spotted all the coasties last night in Gosford :)
has it got green plates?
new numbers plates like "xx-xx-xx"
nah mate, would've remembered if i did,
pretty sure just standard yellow an black
also spotted a white r33 getting sideways in the wet 2day an almost had a date with the median strip. naughty naughty
spotted a white stagea plates STAGEA followed me abit from the boulavarde onto port hacking road then went on princess h'way, nice car ! i was in my parents avalon LOL
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
