Official NSW Skyline spotted thread
CerealKiller
hahaha. No didn't end up getting a helmet after realising there wasn't going to be a discount. :P I'm going to head out to Parra and see what they have.
aww! fair enough! let us know if you find some comfy ones out there :(
on saturday i spotted liz at berowa,
yes i saw you follow but i could not wave looooooooong story.
damn I gota get sum good plates :(
because I have never met you but
as soon as i saw the plates at the lights I knew who you were
Spotted sliver R34 on links rd st ives this morning at 8am
Spotted blue/green R33 on mona vale rd at 8:10am this morning
Spotted silver R34 4 Door on forest way at lunch time
hahaha.. no problems
and everyone said that no one would get the plates with 22 instead of ZZ
losers.
Spotted a grey R33 coupe plates MY33RT driving on Warringah Rd last night, I know your a member but cant remember your sig.. I waved but you would have had no idea who it was ;)
Edited by phillb
You dirty little whore adam
Thanks love.
I spotted a nice yellow R34 going into the eastern distributor tonight after work. I was perving on your car, not your gf in case your were concerned. Had an SAU sticker and yellow number plates but can't remember them now. I rode my bike beside you for a short while.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
