Official NSW Skyline spotted thread
CerealKiller
Was in Sydney for the weekend and to cut a long story short, I somehow ended up in a outer fringe suburb (Annongrove i think?) to visit friends.
I was near a park and an Gun Metal R33 GTST, came gunning past, clutching it in the wet at a pretty decent speed.
He came back after maybe 10 mins later, doing the same thing, except for this time, he lost it and smashed into a pole, writing off the car.
The back of this car was destroyed pretty much, but the guy hopped out ok. Huge crowd gathered and when it dissipated after a few minutes the guy managed to get his car moving, the back of the car destroyed and smoke blowing EVERYWHERE.
In conclusion, this guy was a goose and I'm pretty sure would have died from shame and is VERY VERY lucky, any person in the backseats would have died, so he was save by less than a metre.
Other than that, saw a lot of nice Skylines in Sydney, although bling bling Chromies seem to be much more of a fashion when compared to Melbourne.
Edited by IOWNU
spotted WLD-25L R33 in Westfield Chatswood carpark tonight
Also spotted a black R34 GTT parked in Chatswood Victoria Ave
That black 34 would be mine.. Dont often park on Victoria Ave, But I know im the only one with a black 34 around that area.. so i guess it must be :thumbsup: at that time the car would have been close to stock .. maybe rims? got abit more now :domokun: Hard to remember RTA issued plates isnt it :P
The Silver 33 is a nice machine.. Forget his name but owns a real sweet 33 .. Prob one of the best IMO
Edited by DECIM8
Spotted a broken down gray R32 with bodykit AWU-.. on Epping Road yesterday evening.
Also spotted a black R32 with P-plates turning off Epping Road onto Delhi Road a while later.
spotted a black r32 gtr at kellyville old windsor rd bout 5:15pm plats"MM-0467" or something. not sure of the last 3
I was in the grey gtir next to you.
Spotted Liz this morning at Berowra, and Wilchs car in the usual spot :D
you looked just as tired as I did
could barely put my hand out the window to wave lol.
yep.... that about sums it up ....lol ! Although work thought I looked sick and sent me home early ;)
.....also spotted a black 32 gtr at mt colah late last night he nooded i nooded...
hey mate,
that would be me, have seen you round (just not up close enough).
I thought ur sicker said crim. performance but now i c different
Spotted a gold R33 GTST with an aftermarket front bar and LED hot plates parked next to Canterbury BMW today.
If you're on here, you wouldn't happen to work in the workshop, would you?
hey mate,
i thought it was u.. yeah crim hahaha thats funny. nah its grim its my best mates workshop.
Cruised home tonight about 10:30ish, on Forestway/Warringah rd with a black Series 2 coupe with 17's that looked like AVS Model 5's and stock exhaust. No stickers and stock rego plates so I'm not sure your even on here?
Spotted in Hornsby Westfield Carpark tonight a maroon R33 with 400R rear bar and GTR wing, didn't check the front, looked clean tho. And also a black R33 GTS-T with a veilside front bar, vented bonnet, GTR wing and a GTR badge stuck on the back. :D Also had green P Plates
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
