nah steve.. still has it.
Spotted a silver 32 gtr putting along windsor rd towards parramatta and down james ruse drive... driving like it wasnt double demerits..
also spotted a wine red 32 gtr plates MEL *** chick driver.. doubt she is on here, wouldnt even look over when I stopped next to her.. snoooooooooooooooooooooooby
Last night around 11:30pm on Pac hwy Artarmon spotted BAZ04E - r33 drifter I think you said your nick was?
Also before that spotted a White 32 GTR in Crows Nest again, driving like it wasnt double demerits...
spotted RUFGME? 32 gtr near kirreween
It's RUGAME if it's the silver 32 GTR, and it's Kirrawee if it's in the shire :P the other place is Girraween i think.
Spotted a dark nice looking 32 on heathcote road yesterday headding east, i think i got a flash, either that or he was high beaming the bloke infront of him *shrugs*
    • It's not a dumb question. I was circling this idea myself. User error is always possible!
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
