Official NSW Skyline spotted thread
CerealKiller
Spotted a GT350 Skyline V35 (blue) with SAU stickers in ryde to homebush then you turned onto m4.. Plates ???-50V or somthing.
Have to say car sounds great, was in a Accent drueling over your ride
Thanks Dude,
gotta love that fuijitsubo exhaust, quite as hell when cruising, but nice note when you give it a tap.
hahaa
Dj Albert was my old username lol, it was lame and more lameness so i changed it LOL
but sheng its me :cheers: but im still albert, call me wateves GET IT :D
welllll the white one next to me was a tool, had like 10 woofer run out of 1 one channel amp, and the dude was looking through a crookerd rearvison mirror
...mm must be the subs
youll always be SCHNEGGLES to me boy!
I love having a unspottable euro rocket lol
I always see a white r33 parked near the sports field next to Eastgardens in sydney when I drive to work
Also saw a green 400r kitted r33 on blaxland st in matraville a few months back
I see that White 33 there all the time.
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
