Hey mate it didnt look like this did it?
thats on my desk here at work :(
was in HPI
and it is definatly bodyform.. as thats what the sticker is on the window.
the seats have the GTR logo on em too
spotted a white 32 GTR with Blitz and something else written up the side in large font... also had QLD plates...
Then spotted almost immediately after that a black 33GTR go past me...
I was also infront of a police officer the entire way to work, and didn't even get a second look! :D
I was in a mazda MX5 :D
I did see him give a thumbs up to another officer though, so they do the same thing that we do :banana:
This morning I spotted a Gunmetal R32 GTR with Gold 5 spoke wheels and blue headlights heading North on Military Rd Neutral Bay, I waved but you probably couldn't see with all the rain :D
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
