Hey mate it didnt look like this did it?
thats on my desk here at work :(
was in HPI
and it is definatly bodyform.. as thats what the sticker is on the window.
the seats have the GTR logo on em too
spotted a white 32 GTR with Blitz and something else written up the side in large font... also had QLD plates...
Then spotted almost immediately after that a black 33GTR go past me...
I was also infront of a police officer the entire way to work, and didn't even get a second look! :D
I was in a mazda MX5 :D
I did see him give a thumbs up to another officer though, so they do the same thing that we do :banana:
This morning I spotted a Gunmetal R32 GTR with Gold 5 spoke wheels and blue headlights heading North on Military Rd Neutral Bay, I waved but you probably couldn't see with all the rain :D
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
