Official NSW Skyline spotted thread
CerealKiller
Currently spotting a white R33 gts-t with black bonnet, black wing and R34 rims parked outside my office on Flushcombe Rd, Blacktown :D
If you didn't say R34 rims, that would have officially made me shit my pants!
Its a 370kW ATW GT-R and a HKS T04Z turbo :(
Stock internals, waiting to go boom.
Saw a P-Plater driving it through Parramatta not long ago, so it's a given(going to happen regardless), just accelerates the process.
Edited by Jago
Ok at Parklea Markets today spotted a silver stagea PON-705 with black rims, cooler etc & a black s1 r33 gtst with a full bodykit with stealth wing & black rims. On the way back on cumberland hwy spotted an R34 GTR Vspec pretty sure plates BEO-321..
and i spotted YOU yesterday- just after 7pm heading down teh pacific highway (but you wouldn't have looked twice at the car i was a passenger in)
No honk no wave? Last time you spotted me you nearly jumped out the window of the moving car :)
Spotted Lizzeh in her rocket ship yesterday...
I went to honk the horn and swiftly remembered that I had to unhook it :)
Did you get my message, or have you got another phone number?
why does everyone call my car a rocket ship? Is it like a "i feel sorry for liz coz her car is so little" kinda thing????
It's just a car, like eevvvveryone elses..
but faster
I didn't get any message, I'm pretty sure when I gave you my number I made it up anyway
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
