Spotted two Skylines in the space of 100metres and less than 5 seconds - one was a silver R33 GTSt reversing out of a driveway on Fitzwilliam Rd in Toongabbie, and the other was a black R32 GTSt turning left off Fitzwilliam Rd and into Tucks Rd.
Spotted 2 nice white R33s within about 2 minutes of each other at 11:45am travelling down Roberts rd near punchbowl, greenacre. 1 waiting to turn onto Roberts, either a GTR or trust front bar and GTR wing and the 2nd heading towards Hurstville way, GTR wing with a black blade and what looked to be a trial rear bar. Nice cars if you're on here. :D
You should have stopped and found out! :P
You should always look after fellow import owners, especially if they're in the same car as you :action-smiley-069:
I think that might be e-dog on here too, not certain though...
It wasn't that easy. I was in the far right lane, in heavy traffic, and I spotted him pulling into the hard shoulder on the far left just as I was driving past. Not the easiest thing to get over three lanes into the shoulder and pull up during in peak hour.
iam a truckie, i work down in canberra and spotted R33 GTR BCNR33 plates i think it was.. white one
then also an R34 GTR as well as the powerplay imports nissan navara ute
following soon after on the hume highway heading towards canberra..
round 7.00 last nite
very nice looking cars, must have been heading to wakefield or sumfing
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
