spotted one of the ugliest 33s i have ever seen at olympic park yesterday morning.
light blue with huge chrome dinner plates. ugly!!
cream interior?
it was white/cream. i didnt get that close to it. the only things i know is that it was slow
yeah I know the one haha.. used to see it in the city all the time.. bleh
I'm guessing you guys are talking about this poor R33 that has been introduced to some moron...
spotted you R34 liner today on oldnorthern rd, im not very mature when i spot someone i know on the road (eg, yelling out the window).
i do like the exterior of your car, ive said it before but with the clouds overhead and the headlights on, it looks very stylish...
ahh that was you - nice to put a face/car to a name/avatar - haha i cant tell if your making fun of me for having my lights on during the day or not ;) i must have left them on from when i was in the car park at my uni.
the one we were talking about is lightblue not white
could it be the one that was at the skylines show and shine? I think it was the Toyo tyres s&s over a year ago (or more) and he was caught doing burnouts etc. There was a thread on it with pics but I cant find it anymore ;)
or this one:
Im guessing this was either OF2HVN or FEARGD, I seen these cars around a few times, there the type of tools that always give you the "i wanna fight you" death stare.
Don't forget BL33SN.....
ahh that was you - nice to put a face/car to a name/avatar - haha i cant tell if your making fun of me for having my lights on during the day or not :D i must have left them on from when i was in the car park at my uni.
no im not making fun of you, with the dark clouds overhead and all the car looked great, keep the lights on, they match your numberplate colour lol
Spotted R33 series 2... not looking too healthy at all.
Note the front bumper in the grass at the back...
I feel sorry for you mate.
looks like a powerslide gone wrong..... so thats whatmy car will look like after texi???
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
