  GoldZilla said:
Spotted a silver R34 parked on the street near Blacktown TAFE this afternoon around 2.15pm - had 4WD ride height and wheels that I wouldn't exactly say suited the car. :thumbsup::D
haha i know that one! its pretty ewwww
Hey guys,
I just recently bought a S2 R33, and its amazing how many other skyline owners give you the thumbs up / wave when you see them on the road.
I spotted a Bayside Blue R34 GTR "GTR70Y" in Narrabeen a few days ago, and also saw a Silver R33 S2 turning at Collaroy. Cheers to both of em for the thumbs up!
  XS80ST said:
Hey guys,
Welcome buddy!
spotted a silver R33 S2 just now on norwest blvd
apparently mum spotted a new r35 gtr in parramatta hooning around almost collected her... it was black thats all she got.
Tonight on way home from work spotted liz 180sx in epping and a grey r33 coupe parked.
  EJD001 said:
Spotted SAM916 on the F3 this arvo.. i was the one in the black hyundai accent beeping at u.. had andrew (qantas) in the back trying to wave at u!!
haha he told me about that, had the music up and i was in my own oblivious "i'm still waking up" world!
  Pezhead said:
hehe check out all the skylines I spotted on the Putty Road Cruise.
Putty Rd Cruise Video
typical, I orgsanise the damn day and I get about 2 seconds screen time!!!
hahaah nah jsut kidding, awesome work mate..love the bit where it slows down as the lines pass you going the other way on putty road haha. wicked work!
  evil_weevil said:
spootedthe poor slim mobile with dead battery, poor blue bird couldnt revive teh 32!
it's alive!!! with a new battery...
spotted lots of skylines between epping and penrith and back via the m4
heyyo... i didn't see you anywhere!
spotted dave074 in middle dural today! :D I was off to Wisemans Ferry for a quick drive!
Spotted a silver V35 heading north on Old Windsor Road lat night while I was waiting to turn off Fitzwilliam Road in Toongabbie, then moments later spotted a black R34 going the other way...
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
