2 silver R35s in the space of an hour!
one at the original harry cafe de wheels down in woollomoo and another heading to edgecliff at about 1426 today, plate '206' anyone know what that could mean? the plate not the co incidence.
oh and a burgundy R32 gtst parked just after brookvale oval with plates MIX 32T, very clean.
(last night a light coloured R34 gtst AWK 973 driving very slowly along parra road towards the city through annandale.
R35s still have a lot of presence don't they.
206 Numeral-only plate - my guess is it doesn't mean anything; the numeral-only plates are quite valuable, the fewer the digits the better. Often used as a status symbol and/or investment but values seem to be very speculative.
dropped the gf back to dee why and spotted these on the journey..
the pictured r34 was in the back streets of dee why about 1130 am and gave it a bit of a squirt when he saw me in the rear view mirror, had a hard time keeping up until he parted ways with me at a roundabout, think i saw an SAU sticker so thanks for the run if your on here.
also an r33 that looks identical to mine ARR 42V at 1210 near warringah mall and finally a white very clean R33 GTR parked only military road mosman facing away from the bridge exit, god they look soo much nicer than gt-st's...sniff.
Edited by hamiltonau
Spotted a dark purple R33 GTSt this afternoon rolling through Toongabbie. Spotted it turning onto the railway overpass bridge, then turning right onto Fitzwilliam Road at the roundabout.
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
