Official NSW Skyline spotted thread
CerealKiller
Ahh so you're the person with the gunmetal GT-R with black wheels, nice car mate. I work in Chatswood, I've seen your car a few times.
Also behind ABC
Yeah man! see your car round heaps as well.
My gf rang me up in a panic saying she say someone driving past her with my car, turns out it was yours im 99% sure. ha.
Hopefully see you out there man, Gtr is usually out on the street with a evo 6.5 makinnen and soarer on the weekends.
what have you done to yours man? sounded good.
Spotted red R35 turning into WSID yesterday evening.
JD32R - it's fairly standard actually, just front pipes back exhaust, suspension. I think I had the old 3" back then, it now has 3.5" 5Zigen so it's much quieter.
Loving the N1 boot lip on yours, I want one :(
Ahh that will probablly be the reason. still. has a nice subtle note from outside the car. :thumbsup:
Yeah love the carbon fibre N1 lip, pulled the spoiler off the other day just for something different, and the clean around it properlly, need to re tape the lip down, used slightly dodgey double sided tape. Looking to swap the standard wing out for a CF oem one. just waiting on details.
what 5zigen exhaust is it?? looking to get a new exhaust (apexi N1 3.5") but apparently its going to be massively loud.
JD
Spotted about half an hour ago, a red R34 coupe with dark wheels and SAU sticker going along Cowpasture Rd and went towards the M7 ramps.
JD32R - all I know is it's JASMA approved, has two mufflers. If your exhaust has those little hotdog style resonator then it'll be loud.
Yellow R34 Coupe in Moss Vale.
Haha. I know that guy. Has a sun roof as well. I also think that maroon R32 is for sale too, if I am thinking of the right one.
Edited by JDM34
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
