spotted a certain red 180sx on the back of a trailer heading south along the M7 near the tolls just after 7 this morning.
Also spotted a pretty clean white 33 gtst on the m2, plates were pyro something etc
Silver R34 GT??? for sale at Albion Park.
Forest green R33 in Shellharbour.
Charcol R33 coming down Maquarie Pass, waved, didn't get a wave back.
Hey dude. Pretty sure I saw you heading out toward Robertson earlier at around about 12:15? Don't know if you saw me wave back. Haha.
Yeah mate saw you rolling. Spot the undercover in the 50 zone there?
Nah mate, wasn't paying attention. I was sitting on 50 anyway. Did see some poor twat pulled over near the BP by a marked Highway Patrol where they normally conduct those roadside RBTs though just outside the pools.
Nah must've happened after I rolled through. Theyre always there.
Yeah, they always pick the same spots to do their RBTs. Near the cemetery where I saw you, outside the pools and just before the freeway entrance near Bunnings. I hate the spot outside the pools, got waved in for an RBT there on one occasion and after they let me go, there was a massive ditch at the end and their squad cars blocked the all the space around it so you had to go over it. Spun my wheels on the gravel by accident cause I rolled back slightly as I went over the ditch and they all looked at me, I was shitting massive bricks. LOL.
Edited by JDM34
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
